Strange smell coming from Prius v plastics?
Discussion in 'Prius v Main Forum' started by sandiegoben73, Jun 10, 2014.
  1. sandiegoben73
    sandiegoben73 New Member
    San Diego, California
    2014 Prius v wagon
    I've had my Prius v (lowercase v) for about 6 months now and just took it in for its 5000 mi service. There were no problems but shortly after I got it back I started noticing a really bad odor coming from somewhere in the car. Its not a moldy or mildew smell that's coming from the HVAC. I sniffed all the mats and it's not that either. From what I can tell, the smell seems to be coming from the plastics on the dashboard area, but it's really hard to tell for sure. I tried covering it up with febreeze, but the odor is too strong. It's not the smell of a rotting animal either.
    Again, not from the seats, floormats, or AC system.
    Seems to be coming from the dashboard and/or center console area where all the buttons are. I have a baby and a carseat, but I don't feed the baby in the car, and after sniffing the carseat and rear seat area, I can confirm the smell isn't coming from there.
    Anyone else have this problem? What were your solutions? I'm about to take a multi-day cross-country road trip in my Prius v and would love to fix the source of the smell before I go. It's not that noticeable with the windows rolled down, but when you sit in the car for the first time in the morning, the smell is definitely noticeable, and it's not good. Your help is appreciated!
    49,371
    sounds like the tech left the o without the b.
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    Check the cabin filter under the bottom glove box.
    It might be animal intrusion, which is common with a large number of Prius models.
  4. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Mike is absolutely correct and even if you are the only Prius that mice have not yet visited, the filter can be a source of odor...get em cheap on Amazon
    PS: I have never liked to use Fabreeze but it has its uses I suppose. Arm and Hammer baking soda is one possibility...just have box in there to adsorb odors (not spread it around).
    #4 wjtracy, Jun 10, 2014
  5. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    I think the odor is coming from the detailing junk that the dealership puts on your dash to make it look shiny. The person applying it used a wet old sour rag to apply the material. Had that happen to me a few times even though I specifically tell them to NOT detail the car. I had to use a clean wet towel and to wipe the junk off.
  6. sain
    sain Junior Member
    Akron, Ohio
    I have the same problem. I wonder if you got rid of the smell. If so, how? Thanks.
  7. HansRobert
    HansRobert New Member
    South Central PA
    2014 Prius v wagon
    This is almost exactly the same experience we just had. Took the car in for 5000 service and since then we have a strong odor present. It is a strong "fishy" odor. I took everything out of the cars, checked under the seat, glove box, even checked the cabin filter nothing. But then I literally put my nose on the floor and finally determined it is coming from the carpet on the passenger front. It seems to be centralized in one spot. We just bought carpet cleaner and I plan to tackle this tomorrow. I'll post results.
  8. mikefocke
    3,692
    1,644
    Sanford, NC
    I took a bag of trash to the dump. The bag contained apple peelings that had been sitting in the bag for about a week. The bag contained apple juice from the peelings which leaked out of the bag and into the rear storage compartments and spare tire well. Only a thorough cleaning of those areas and about a month of running the fans on high got rid of the smell.
    These smells can come from anywhere.
  9. HansRobert
    South Central PA
    2014 Prius v wagon
    Yes I totally understand what you are saying but in this case there were no bags leaking into the car. The smell was under the floor mat. I tried carpet cleaner and it is somewhat better but not completely gone. I just cannot figure out what is causing the smell.
  10. bisco
    49,371
    i'll never have my car detailed, lesson learned.
  11. ernie1
    67
    Sacto,Ca.
    Some people have luck with an enzyme cleaner that you can get at a pet store. It's used to neutralize urine odors.
  12. bisco
    49,371
    i wonder if an ozone machine would work.
