Strange smell from heating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Arthur Daily, Jan 17, 2009.
  1. Arthur Daily
    Arthur Daily New Member
    London UK
    Hi all, I found this site extremely helpful in making my decision to get myself a prius. Now 5 weeks later i'm still a happy prius owner. I've done a little forum search on this and only found posts regarding 'smells' when using A/C, but my problem is i get a smell when Ive cranked the heat up. not had a chance to use the A/C for cooling yet as its DAM COLD here in London right now. My problem is this, I've used the heating set at around 20 for about 2 weeks then the other day i needed some heat FAST so cranked it up to MAX. then a few moments later i noticed a strange smell in the cab. i wouldn't say its a burning rubber smell or even a electrical burning smell. its doesn't smell like one of those sort of toxic smells. more like one of those old bar heater smells, but not so much of a dusty smell. if i set the system to use outside air, it helps. but doesn't completely go away. I'm going to play with the setting a little more over the next few days and try to pin point exactly whats what. but from my story above dose anyone have any ideas ?
  2. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    Possibly a rodent smell? My understanding is that mice can infiltrate the HVAC system of the Prius. Try pulling the cabin air filter and investigate, maybe do a smell test. The element is washable.
  3. Patrick Wong
    18,200
    6,472
    Hi Arthur,
    The Prius cabin air heating system includes two electric heaters, along with the traditional heater core that has engine coolant flowing through. Maybe the smell that you notice is coming from the electric heaters.
    kidfried likes this.
  4. skguh
    skguh Member
    195
    Montgomery, Alabama
    I had the same occurrance--twice.
    Additionally, I usually leave everything on automatic--just bump the temp up or down depending on circumstances. I tried this morning and it (air handling system) started trying desperately to heat at the foot level but my windows increasingly fogged up. It's as though the air conditioning gets confused--and yes, I realize that's silly. But I've been driving the same way for months. After the above I pushed the temp to HI and it wasn't any more than a minute before it smelled like my dash was going to burst into flames. This is the second time the smell has occurred, both times seemingly associated with the 'HI' setting. This isn't a hot ceramic smell, but a very very hot electrical smell.
    I'm taking it to the garage for 35K checkup tomorrow. Will advise.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The electrical heaters are not normally used, but when you cranked up the heat they came on. Electrical resistance heaters make a funny smell when new, or when used infrequently. Think of it as burning off the crud in the bottom of your oven, but in a more limited manner.
    Tom
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    If you have snow on the intake vents (between the windshield and the hood) and the automatic system goes to 100 percent heating, with a cold engine, one can get the electric smell. I clear off the vents carefully, and hammer down with the brush bristles, any icy deposits in the metal grid under the grill. This appears to help the air flow, window fogging, and gets rid of the electric smell...
  7. skguh
    skguh Member
    195
    Montgomery, Alabama
    I've only used my heat "HI" setting twice, and both times this odor came. It was so acrid I looked for smoke--I honestly believed my system was frying. Eventually the smell subsided, but not before I rolled the temp back down and set it on 'Auto' air handling. Serious reflection moments, those...
