Strange sound after shutting engine off
Discussion in 'Gen 2 Prius Main Forum' started by 420benz, Mar 4, 2011.
  1. 420benz
    420benz New Member
    lawrenceville Ga.
    Very hard to describe this sound but it is coming from under the hood and lasts for about 10 seconds.
  2. SWAT Native
    SWAT Native Junior Member
    Atlanta
    Is it a whirring or humming kind of sound? Mine does that, too. I figured it has something to do with the electric motor shutting down.
  3. 420benz
    420benz New Member
    lawrenceville Ga.
    YES. It always had a humming sound,but it is much louder now and lasts longer.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Perhaps you are referring to the sound of the pump on the coolant heat storage tank? After you shut off the car, this pump fills the thermos-like tank with hot coolant so that the engine can warm up faster and have lower emissions on the next start.
  5. Patrick Wong
    18,200
    6,471
    You should hear a similar sound as you are starting up the Prius for the first time in the morning.
  6. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    If you peruse the Owner's Manual, you will see several entries concerning various sounds that the Prius makes, when the engine is not running/Power is not "ON".
    All of these entries note that "this sound is perfectly normal"
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I have never been "perfectly normal", what's that like?
    Scallywag likes this.
  8. seatown7
    seatown7 Northwest Prius Dork
    Seattle, WA
    2013 Prius Plug-in
    I've heard its quite boring and tedious...;)
  9. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    "Normal" is a setting on a clothes dryer.
    For the rest of us, "Functional" suffices :thumb:
    Scallywag and alekska like this.
  10. 420benz
    420benz New Member
    lawrenceville Ga.
    Thanks guys. This is a great forum.
  11. richard schumacher
    7,663
    1,038
    United States
    It could be the sound of the coolant transfer pump failing. A failing one tends to get noisier in cold weather.
  12. 420benz
    420benz New Member
    lawrenceville Ga.
    Where is it located and is it a DIY replacement?
  13. Patrick Wong
    18,200
    6,471
    It is located near the coolant heat recovery system canister, in the front left wheel well in front of the tire. Replacement could be DIY if you consult techinfo.toyota.com or look up my post about how to replace engine coolant.
    However I wouldn't go to the trouble of replacing the pump just because it is noisy. If no DTC is logged by the engine ECU (which would cause the check engine light to appear), then no worries.
  14. Sam23
    Sam23 Junior Member
    Mobile, AL
    I have a 2007 Prius with a similar noise that seems to be getting louder/more obnoxious. Did the pump ultimately fail regarding the original post on this thread?
  15. PPENDOR
    PPENDOR New Member
    Fayetteville, AR
    Maybe not, I have a 06 prius. the Inverter Pump get relative gentle noise in summer and loud in winter. I tried to bleed the pump. Yes, few air seems like comes out but it doesn't help about the noise issue. Never mind, I just ignore it. I will change the coolant in next summer regards to the 100K mileage.
  16. CooCooCaChoo
    CooCooCaChoo Senior Member
    899
    501
    Cow-lee-fornia
    2023 Prius
    Yeah theres a buzzing sound that comes from the front of the car, lasts bout 10 seconds max.
  17. bisco
    49,371
  18. Gino Veltri
    Gino Veltri Member
    394
    40
