Strange sound under the steering wheel. Link to video
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by igorsoftappi, Sep 13, 2017.
  1. igorsoftappi
    igorsoftappi New Member
    MD
    Help please. Today I start hearing some clunky noise under the steering wheel. It happens when I start the car and continues until I stop it. I filmed it, here is the link to video
    It turns out that some plastic parts are hiting each other. Does anyone know why this parts under the dashboard are moving? Thank you in advance.
    48,862
    i'm wondering if it's part of the hvac system, and it's jammed.
    igorsoftappi likes this.
  3. JC91006
    16,463
    8,377
    Put some grease on it. It's probably the servo that controls the temperature in the car. Try turning off the AC and see if the sound goes away.
  4. Osxarsam17
    Osxarsam17 New Member
    US
    igorsoftappi and bisco like this.
  5. RRxing
    RRxing Senior Member
    2,516
    1,789
    NEPA
    That's my guess as well. Could be the linkage controlling the HVAC vents for inside/outside air.
  6. bisco
    48,862
    how many miles on her?
  7. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    The slide Post is not in the actuator Cam or it broke off turn a.c. on off and you should see the cam moving with a slide pin that should move inside the cam
  8. igorsoftappi
    MD
    thanks, that definitelly will reduce the friction. Still not sure if is something broken or it's normal.
  9. igorsoftappi
    MD
    120000 miles I guess. 210000 kilometers.
  10. igorsoftappi
    MD
    the highlighted button from picture redirects air to front windshield
    in video you can see how it changes
    I put some oil and it helped for now )
    bisco, SFO and Raytheeagle like this.
  11. bisco
    48,862
    fairly common complaint in older pri.
  12. ChapmanF
    14,971
    The device that moves that linkage around is called a 'servo', and there are two parts to it: a motor, obviously, and a position sensor so the HVAC computer can compare the position it is in to the position wanted.
    In Gen 1 and Gen 2, the type of position sensor is a plain old potentiometer that can get noisy (in the electrical sense, I mean) with age. This is the same thing that happens in Gen 1 with the accelerator "big hand syndrome" or the power steering shaking the wheel.
    The computer is using the motor to try to hold the servo in one position, while the electrical position signal coming back to the computer is jumping around.
    You can either replace the servo with a new one, or just clean the potentiometer inside. Easy, problem solved.
    -Chap
    fotomoto and igorsoftappi like this.
  13. eman08
    eman08 Active Member
    360
    192
    US
    That's just your Air flap servo motor acuator making that noise. It's quite common on many Toyotas. Mine does it too. It ain't going to hurt anything as long it's working. Just live with it.
  14. ChapmanF
    14,971
    Just living with it is an option, though it is making unnecessary constant motion, and likely to wear out faster. It's easy enough to fix I don't see much reason to have to put up with it.
    -Chap
  15. Lesk_The_Glut
    Lesk_The_Glut Junior Member
    52
    22
    Bakersfield, CA
    I got the same problem. At first, there was this strange sound, kind of like grinding. It made me think of some tiny animal...mewling. LOL. I do not know. But it wasn't very loud. Eventually, I found that it would make the sound whether or not the A/C was on. But if I did turn the A/C on and hit that front defrost vent button, it would go away. Then I had the dealer under the dash replacing an A/C part.. it may have been a condenser core, I forget. But directly afterwards, the sound went from a grinding sound to a clunking sound. About four months later, now that vent and just does not work. A little air escapes but there is something in the way and it won't actually blow.
  16. ChapmanF
    14,971
    It bears repeating—if you have a Gen 1, or an older Gen 2, old enough that one of the heater servos has become noisy and is waffling back and forth, just fix it. It is easy to confirm what the trouble is (just bend down there and watch) and easy to fix (just take servo out, clean, reinstall).
    If you leave it waffling for too long (years, I'd guess) it will probably wear itself out eventually. That would still be easy to fix, but you might then end up buying the part rather than simply cleaning it.
    -Chap
