Strange Sound When Backing Up
Discussion in 'Gen 4 Prius Main Forum' started by Colorado Boo, Jul 22, 2021.
  1. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    I asked AMD (the Car Care Nut on Youtube) about this sound and he told me to get it on video, so I did. It's hard to describe (especially with the stupid backup beep) but kind of sounds like a hum of two thin sheets of metal rubbing together.) Yes, it makes the sound every time I back up.
    Our 2017 Prius makes no sounds like this when backing up, and never has.
    Have a listen....anybody else have this? (It is an AWD car but not sure if that makes a difference.)
    49,696
    that's your VPNS vehicle pedestrian notification system. it was adjustable in 2017, now it is required by nhtsa.
    it is on forward and backward up to around 18mph, but the conditions have to be right to hear it inside the car.
    toyota has had it since 2012
    nhtsa was petitioned by the federation for the blind, because they were being killed by prius left and right because they were too quiet.
    the back up beep is for you because toyota drivers are all old and senile, and can't detect which direction they are going
    #2 bisco, Jul 22, 2021
    jerrymildred and Pulse07 like this.
  3. Pulse07
    Pulse07 Active Member
    273
    139
    East Bay, California
    2020 Prius
    XLE AWD-e
    Thats what I am hearing, its the "HUMM" for pedis unless I am not hearing what you are describing. Set a gopro shoot a video of yourself moving forward and in reverse , you'll hear the hum
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    Yup! It's the pedestrian warning system. Much louder outside the car on the new ones. My 2017 is almost inaudible on the loudest setting. Gotta make sure the EVs are 10 times louder than the RAM 2500 diesels.
    Mambo Dave and alanclarkeau like this.
  5. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    And I think it could be worse. The Honda CR-V hybrid sounds like a chirping robotic bird.
  6. Pulse07
    273
    139
    2020 Prius
    XLE AWD-e
    the sound volume can be changed?
  7. jerrymildred
    11,518
    14,124
    Tampa, FL
    Yes if it's previous to the 2021 MY. It's the first item on the customizable feature list in the 2017 owners manual. The manual says a dealer has to do it, but lots of OBDII phone apps will also allow you to change this along with a bunch of other settings.
    Pulse07 likes this.
