Strapping Queen Mattress on the roof
Discussion in 'Gen 3 Prius Main Forum' started by Meh, Aug 3, 2018.
  1. Meh
    Meh New Member
    Madison
    I'm planning to strap a queen mattress (spring) on the roof of my 2015 prius two, and move it across town for about 5 miles on local avenue or 7-8 miles on back roads. Has anyone tried something similar / any tips on moving it as safe as possibly? Also, if anyone's got a photo of this actually happening, please share. It'll do a lot to ease my mind!
    *I would use uhaul vans/trucks instead if I could, but sadly they're all booked on the date that I have to move.
    52,597
    shouldn't be a problem, just open the windows and tie a rope around it a few times.
    if it sags to much and blocks your view. put a sheet of plywood under it, or some 2x4's.
    rogerdpack likes this.
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    Is the mattress bendable enough to sort of fold and jam it out the back of the hatch?
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Sure there is risk. But if you secure it well enough it shouldn't be a problem.
    Secured and not impeding your vision.
    Also a good thing if you are taking side roads.
    I was on a 45 mph stretch, although admittedly everyone goes 55 mph or higher, and I saw a mattress flip off the top of a car and into the middle of the 3 lane stretch. It happened so quickly, it was really lucky it didn't cause a big accident.
    So Slow, Secured, and keep your vision clear...and you should be OK. Good Luck.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,060
    789
    Virginia, USA
    Also, try to have down force on the mattress with the air flow.
    In other words, you do not want to catch air under the front of the mattress and thus have the air work to pull up on the mattress away from the roof, straining your method of tying it to the roof.
    If the front of the mattress was slightly lower than the back of the mattress, then the airflow would push down on the mattress, towards the roof.
    The biggest thing is go slow. Air resistance is not linear but proportional to speed squared.
    P.S. Obviously protect your roof from scratches!
  6. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    If you're in Colorado Springs, you can use my truck :)
    Take a pic and share your experience! Should be no issue with some rope and going slow!
  7. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    SCIENCE!!!
  8. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    A spring mattress is bundled in wood.
    Bad idea unless some sort of wrack is fitted,
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    SCIENCE BITCH!
    RRxing likes this.
  10. padroo
    padroo Senior Member
    2,763
    2,253
    I would put a blanket on the roof to protect the paint and use two ratchet straps, go through the back window with the windows down and try to go through the open doors and see if they will still close, unless you are a Boy Scout and know how to tie some good knots. Good luck
  11. Mendel Leisk
    42,100
    Yeah think it through with the ropes. My brother-in-law many years ago (rest his soul) showed me how to put small lassos along the length of rope, loop the end of the rope through the lasso and really cinch it down. Make sure it's secure side-to-side and front-to-rear. And for sure don't use bungee cords, nothing elastic.
    Johnny Cakes likes this.
  12. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Or just rent a uhaul truck for $25 safer quicker and you won’t scratch the crap out of your car,
    Grit likes this.
  13. Johnny Cakes
    1,060
    789
    Virginia, USA
    Oh yeah!
  14. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Breaking bad reference lol.....
  15. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Uber, if a driver has a truck, just message them if they can haul it in the truck bed. If not, cancel within 5 minutes of request and not get charge for anything.
  16. Mendel Leisk
    42,100
    I need to pick up a 4'x8' gyprock sheet. I was thinking to cut it into quarters at the store. But now I'm starting to think big: it would avoid some superfluous joints.
  17. EChua5
    EChua5 Junior Member
    Haven't tried queen mattress spring, but queen mattress foam fits in mine
