Stress crack in hatch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scottv, Mar 29, 2016.
  1. Scottv
    Scottv New Member
    Warrington pa
    I found this crack on my car. Is there a way I can seal it so no damage occurs. I understand Voukd cost over a thousand to fix. There is no indication C impact or anything. Looks like a stress crack
    51,140
    welcome! never seen anything like it. it's aluminum, so, repair may be difficult. how about a salvage unit?
  3. Scottv
    Scottv New Member
    Warrington pa
    I
    It's plastic not metal
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    just buy a used piece and replace it.
  5. Scottv
    Scottv New Member
    Warrington pa
    Unfortunately I don't have that much mechanical skill
  6. bisco
    51,140
    it's not the hatch then, can you take a pic from further away?
  7. Scottv
    Scottv New Member
    Warrington pa
    No it's right under the glass and it covers the handle that's used to open up the hatch opens fine it's a very small crack right under the glass and it's above the opening where the license plate is it's to the right of the handle that opens the door the hutch rather
  8. bisco
    51,140
    check in at a hardware store, there must be something that will fill and fuse that together. i wonder if bondo would work.
  9. Patrick Wong
    18,200
    6,492
    Who told you that?
    You can buy a new, painted lift gate trim for $197 (plus shipping) here:
    EXTERIOR TRIM - LIFT GATE for 2009 Toyota Prius
  10. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    A legit body shop can plastic weld that rack for you and respray the area if cosmetics are a concern.
