Strong “jolt” when the gas engine kicks on and off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Krisdonath, Jan 8, 2019.
  1. Krisdonath
    Krisdonath New Member
    Colorado
    When my 2008 Prius w/ 178000 miles in stopped and the gas engine kicks on or off, I feel a significant movement in the engine area. The car didn’t use to do this and I’m wondering what the fix may be. I swapped out the mount on the bottom of the motor but that didn’t seem to have any affect.
    SFO likes this.
    51,155
    does it happen even after the engine is hot?
  3. Krisdonath
    Colorado
    Yes, typically when the heat or A/C is on.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Yes there's is a significant jolt once in a while when the motor starts and stops. Pretty normal. Its probably worse if the car needs a tune up.
    Mostly new owners post about that. You'll get used to it.
  5. gptoyz
    gptoyz Junior Member
    79
    16
    los altos
    I'm chasing this down myself
    I got my rehab prius a few weeks ago.
    I changed out the oil, mobil1 0w-30 and did a transmission drain/fill, changed out the PCV, spark plugs and filter
    My cat is also super clogged, I'm waiting for my new one and the cat donut gasket is partially blown out
    wbs887700 likes this.
