Struck by lightning
Discussion in 'Prime Main Forum (2017-2022)' started by 70ghia, Apr 28, 2022.
  1. 70ghia
    70ghia Wally
    central Florida
    I just got my 2020 Prius Prime back from being fixed after being struck by lightning a month ago. It has been at the local Toyota dealer's service center the entire month.
    Last month the car failed to go to a "Ready" state when I got into it. It would just go to "Ignition on" and would rotate to "Accessory" But it would not go to a "Powered off" state. While in "Ignition on" it would display several errors on the screen. Those included, "Shifter disabled", Breaks malfunction", "No engine oil", "PWSD failure", "Forward camera failure", and many others. Most ended with a statement that the car needed be serviced.
    Toyota roadside assistance came out and disconnected the 12V battery several times trying to reset the ECU to get it do something. But the car kept going back to the same state of rotating between "Ignition on" and "Accessory". But not really doing anything more.
    The Tech finally figured out that if he put on the emergency break, that he could then press "Park" and power off the car. He was initially concerned that he wouldn't be able to tow the car given that the shifter was disabled which left the car stuck in park. But he used skids to pull the car onto the tow truck without too much trouble.
    While being services, they replaced the ECU initially and then found out that the hybrid battery computer also needed to be replaced. All said, the final bill was just under $3200 and included 7 hours of labor. I didn't think that was too bad. Insurance took care of most of the bill (except for my deductible.)
    Insurance approval and the hybrid battery computer being on backorder for about 10 days were the bulk of the delays in getting it repaired.
    vvillovv, Gokhan, drash and 1 other person like this.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Last summer, we lost our 2018 Prius to an electrical “surge”. We couldn’t find a strike point but the car was sitting under a large tree in over a foot of stormwater on the right hand, curbed side during the storm. Kids were home and heard the massive strike(s). Our home lost several items and next door neighbor did too. His driveway flows water out to the street. It took out both rear ABS sensors, the ABS system, power brakes, a/c, and who knows what else before insurance + dealer prices/labor totaled it.
    Upside: replaced with ‘19 Prime (before high gas prices really sent hybrid pricing thru the roof).
  3. Washingtonian
    Washingtonian Senior Member
    715
    616
    I have learned two things here. First, I thought the tires would keep a car from being grounded, so lightning would not strike it. Of course, sitting in a foot of water would negate that. Second, I didn't realize that insurance would cover lightning damage to a car.
  4. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I think it is covered under the comprehensive insurance. I just made a claim when rodents chewed some of the engine wires on my BMW.
  5. Gokhan
    Gokhan Senior Member
    4,619
    1,855
    Paramount CA
    It wasn't lightning. It was this—an electromagnetic pulse (EMP):
    vvillovv likes this.
  6. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Did you know that the car was struck by lightning before calling Toyota, or did they conclude that was the cause by some evidence?
  7. 70ghia
    70ghia Wally
    central Florida
    I didn't know that it was hit by lightning or an EMP until after the service department concluded that was what happened. There was no damage externally to the car at all.
    It is covered under comprehensive coverage as an act of nature. I have All State and a vanishing deductible. However, the vanishing deductible doesn't apply to comprehensive coverage. So I had to pay the deductible. But that was better than the entire amount. It was actually done in stages. The first estimate covered the ECU. Once they replaced that they could do diagnostics to see what else was damaged. That was then they found the hybrid battery computer and did another estimate which also needed insurance approval. The server tech and the insurance adjuster talked like this was fairly normal process in this situation and that they might need to go back and forth a few times to get everything resolved.
  8. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Next time, maybe don't go storm chasing. :eek:
    Code:
    https://www.youtube.com/watch?v=s25MK1T1icw
    CAR STRUCK BY LIGHTNING!!!
    Apr 13, 2022
    High Risk Chris
    Btw, I'm glad that your car is working again.
  9. fuzzy1
    10,159
    If there is enough voltage to jump across 10,000 feet of air above the car, then there is enough to jump across a mere 5 inches of air below the car. Cars have been getting hit by lightning even since cars existed.
    Others have also pointed out that some tire formulations also include additives that happen to make them more conductive than old fashioned pure rubber.
    Only the Comprehensive option covers it. This element is not a legal requirement, so many people drop it on older cars, sometime after any financing has been paid off Lenders typically require you to have it.
    Washingtonian likes this.
  10. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    That does not seem like a good way to try and charge your car.
    Hicksite and vvillovv like this.
  11. Trollbait
    11,510
    Perhaps if you need to travel time.
    vvillovv and huskers like this.
  12. bisco
    49,388
    was there a lightning storm?
  13. 70ghia
    70ghia Wally
    central Florida
    Sorry for the late reply, Bisco. I was out of town when it happened. But I live in Central Florida and there is usually frequent lightning storms starting up this time of year.
