Strut Choice: Sensen vs KYB vs Monroe
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jzchen, Jun 15, 2020.
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The Sensen complete strut assembly is much lighter than the KYB version. I kind of ruled out Sensen based on that, equating heavier with stronger/sturdier. (I don't think you're going to get special metal with the pricing on the Sensen units).
    Monroe has a limited lifetime warranty that DOES COVER WEAR OUT. But does not list a complete assembly for the v. It does list 172683 and 172682 for a Scion tC. Interestingly KYB's SR4520 and SR4521 are listed for both the tC and the v. So thinking it may be safe to use the Monroes on the v.
    Thoughts? (Brought the idea up at lunch with my son and he said to contact Monroe with that info and ask).
    Thanks for reading!
    moto g(7) power ?
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Still waiting for a response from Monroe. GAWR on the tC is higher than the Prius v.
    moto g(7) power ?
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Finally decided to call them. Monroe does not advise to use them on the Prius v. No warranty if they don't work out for you....
    moto g(7) power ?
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I wouldn't put Monroe shocks/struts on any car I own even if they were giving them away along with a free gas card.
    I'm not familiar with Sensen, but I'm sure they're just the cheap no-name crap. Additionally, you'd be replacing quality OEM Toyota springs with more crap.
    So yes, I'd recommend going with KYB -- they will be excellent.
    Fostel and jzchen like this.
  5. Leadfoot J. McCoalroller
    8,141
    7,643
    Pennsylvania
    2018 Prius c
    Sensen is junk.
    Monroe is not wonderful.
    KYB is fine, as far as I know they were the OE builder anyway.
  6. flexthatdx
    flexthatdx Junior Member
    22
    I was looking into the Tein EnduraPro shocks/struts. This is a new product from Tein and not much used in the states yet.
    jzchen likes this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Thanks guys for sharing your knowledge. And thanks for sharing the Tein options. Looks like they have an adjustable damping style as well, like KONI Sport, which doesn’t make anything for the v.
  8. flexthatdx
    22
    If you want the dampening option then you can get the EnduraPro Plus. The benefit I see to these Tein shocks is that you get a better shock than OEM and you can still use your stock springs to retain the OEM height.
    jzchen likes this.
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Searching the v part of the forum for "strut" brings up some interesting info. There is a concern regarding the KYB strut making some noise when in reverse. There are two cases where the poster noted they used Monroe OE Spectrum struts, but never came back to update how they worked out. I found absolutely nobody mention they tried the Sensen units.
    I really like the idea of the adjustable damping Tein, but when I read their warranty terms I felt the length is short. Still hoping for a more complete assembly, but I'll comment on my search for that further down.
    SiennaChat has some KYB concerns in the Gen 2. Someone noted that the springs for the Gen 2 complete assembly have an extra coil, which makes for some issues, coil impacts itself on compression causing wear. Solution was to add a rubber hose or the like as a cushion, but in wet weather that starts to squeak. I guess no manufacturer is perfect.
    Regarding the three manufacturers in the thread title, only KYB lists the same complete strut for the similar year Scion tC and Prius v. Sensen lists a complete strut for the Prius v only. Monroe lists for the tC only as I mentioned. KYB lists the exact same upper mount for both applications, but Monroe lists different part numbers for each....
    moto g(7) power ?
  10. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Prius v shocks totally different front and back from Hatchback.
    And the wheel bearings are different.
    jzchen likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Thanks for that info. I wasn't considering Prius hatchback parts in substitution, but Scion tC front struts, which KYB sells the exact same for both.
    I ended up throwing in the towel on this choice for now. I found a caster adjusting bushing set from SuperPro Bushings Australia and have them on order.
    moto g(7) power ?
  12. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Just put that in for anybody else reading these posts.
  13. OpalCorsair
    OpalCorsair New Member
    Maryland
    2014 Prius v wagon
    I was told at my last oil change that my left front strut is leaking. I have a 2014 Prius V with the Two package. I'm getting the impression I should replace with a KYB strut. Can someone tell me the differences between the various types of struts? Advance Auto Parts has a "Gas Strut" and a slightly more expensive "Excel-G Strut".
  14. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    I wasn't either...... but that's how they came. Just make sure the parts are for v..... I had to send back for the correct ones. Soon as you get them take out of the box and check. It's a hassle if you've already tore your car apart.
    Plus: Seems like quite a few prius have one of the rear wheels not correctly aligned with the front....
    jzchen likes this.
  15. Leadfoot J. McCoalroller
    8,141
    7,643
    Pennsylvania
    2018 Prius c
    Excel-G is a model name used by KYB for their gas struts. I can't tell you what they meant by "gas strut" as a different item.
  16. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    @OpalCorsair -. The more expensive one has a 1 yr warranty and the cheaper one has lifetime. They both mention Excel-G.
    @Tim Jones - Still waiting for the darn bushings. Seems like it's going to take a long time...
    moto g(7) power ?
