Strut replacement and squeak issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sciencekit, Jan 4, 2012.
  1. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    I need to replace the front struts on my 2004 Prius (195,000 miles). Any suggestions on which hardware to best replace them with?
    Also, I have noticed when parking, the car tends to slightly sway forward and back with a squeaking sound after it comes to a stop. Doesn't happen when I brake, but rather when I let off the bake after parking. I assume (yup, know what that means) this is somehow due to the worn struts. Anyone else had this problem?
  2. sciencekit
    76
    Norfolk, VA
    No one? Dang. On my own. lol
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
  4. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    The other forum I frequent is saying that the KYB replacement struts fail early due to poor quality and instead recommended Monroe sensatrac.
    MB860 ?
  5. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    On the Prius? I hadn't heard that before. My own experiences with KYB have been excellent.
  6. The Critic
    3,193
    2,327
    CA
    In general. I would expect the Prius to be similar to most passenger cars.
    MB860 ?
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Truthfully, I went with Toyota OEM at a dealer. 195k miles is a LONG time if you're on original struts. Mine were "done" at 110k.
    ABSORBER ASSY, SHOCK (FL) 4851049505 1
    ABSORBER ASSY, SHOCK (FR) 4852049585 1
    ABSORBER ASSY, SHOCK (Rear) 4853049385 2
    If I'm not mistaken, KYB OE's the Toyota struts.
    At a particular Toyota parts website, the fronts are $96.71 each, the rears $61.35 each. This didn't include replacing dust covers (which should have been done), and will require a 4 wheel alignment as part of the installation.
  8. The Critic
    3,193
    2,327
    CA
    True, but remembrr KYB OE and KYB aftermarket are different.
    MB860 ?
  9. sciencekit
    76
    Norfolk, VA
    Yeah, 195K miles is a bit long but up until now they seemed just fine. Any idea on what the squeak could be?
  10. bstephens
    bstephens Junior Member
    36
    Oklahoma
    My original struts started leaking at 150,000 miles, and I replaced them with Monroe sensa-tracs. Used Monroes mostly because a mechanic I know said Monroes were better than KYBs. I really do not notice any difference, and now have 50,000 miles on the new struts. Another 100,000 miles and I will see if these new ones are leaking!
  11. sciencekit
    76
    Norfolk, VA
    IS there a difference between KYB GR-2/ Excel-G and the OEM versions I can order from Champion Toyota? Besides the OEM versions higher cost?
