Strut-Tower bar does work !!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Azipod, Oct 3, 2010.
  1. Azipod
    Azipod Member
    139
    NorCal
    Thanks to Gadget-Dad with post: http://priuschat.com/forums/gen-ii-...-strut-tower-brace-install-pictures-text.html , I was able to get my Tanabe Sustec strut tower bar installed this afternoon with ease. Total time was about 1 hour.
    Results? It does work! My placebo seat of the pants effects tells me that it's a worthwhile add-on for the Prius. I was pretty skeptical of the results earlier and just thought I do the mod for fun. I've owned several cars in the past to which I also put the strut-tower brace (most of which were German) and they never made any noticeable improvement. The shiny bars on those cars just looked pretty! :) However with the Prius, the improvement is almost night and day. In the turns, the vehicle feels more planted and there's more control in the car as oppose to a slight sloppy-ness feeling. I can't explain it, but I actually think it reduced body-roll too! I always thought only springs/shocks/anti-roll bars are the only mods that prevent roll but maybe not?
    I guess the Toyota engineers really skimmed on chassis rigidity in their design to save weight ... and thus we get a very flexy chassis which hurts the handling. It feels like we're driving a wet-noodle.
    Btw, I got the Tanabe Sustec bar from JuicedHybrid for $129. No need to spend $250+ on the other bars. This one fits perfectly.
    The $50 eBay G7 chassis brace will be next weekend's project. Stay tune....
    Jonathan L likes this.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Yup, I have one installed too and it does makes a big difference. It is a great handling improvement mod that is well worth the price.
  3. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    Any clearance concerns with the Tanabe Sustec bar? Such as the brake reservoir, and can the inverter coolant cap be easily removed still?
    Animull and Leon1972 like this.
  4. gigabyte
    gigabyte Junior Member
    26
    oakland
    i too have the tanabe strut bar. it does block the inverter coolant cap, but if you loosen the adjustment nuts to can angle the bar out of the way to gain access. i got mine from evasivemotorsports.com for $97
  5. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    I can still remove the inverter coolant cap. It is not as easy as before but it is possible.
  6. Azipod
    Azipod Member
    139
    NorCal
    Yes, you can still remove the coolant cap. It depends on how much you want to angle up the bar. If you leave it completely level, it blocks it. i angeled it up a bit, just as much that I can get the cap unscrewed and can put a funnel in. I imagine if you angled it up higher (provided it does not hit the hood) so u can take the cap completely off, but it might look unsighty and i'm not sure how high u can go before it rubs on the underside of the hood.
    Either way, good worth while add-on! True thumbs up for this mod!
  7. roverguy78
    118
    24
    San Antonio, Texas
    What about the adjustable preload of the Tanabe bar? Did you guys raise the front of the car and adjust the bar, or simply install the bar with wheels on the ground?
  8. Azipod
    Azipod Member
    139
    NorCal
    Per the Japanese printed instructions that came with the Tanabe bar, the photos do not seem to suggest that you need to raise the car to install.
  9. Azipod
    Azipod Member
    139
    NorCal
  10. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I'm thinking of going for the Tanabe strut tower bar and doing this mod. Can somebody tell me the exact tools I'll need for dis-assembly/reassembly? Where can I find a DIY for this specific bar? I'm so unhandy it's not even funny..Yalls installed this in an hour, I think it'll take me 10.
  11. Azipod
    Azipod Member
    139
    NorCal
    "GadgetDad" had an excellent write up with spectacular photos -- it's somewhere online here.
    I followed his instructions and got it done witin 2-hours and I took my sweet time. It was a fun, easy, slighty intensive but not difficult project. I had a great time doing it on a weekend morning!
    GOod luck!
  12. macmaster05
    4,050
    729
    Thanks azipod. I've actually browsed through Gadget Dad's write up, but I'm still not sure what tools I need exactly. Quite honestly it looks a little daunting.
    The last thing I want to happen is to be mid-way through the mod, realize I don't have the right tool and bam - I'm stuck. Or, run into a step that makes me turn and scratch my head and bam - I'm stuck. Or similarly, run into a step that makes me worry that I'll break/destroy my car's parts and then bam - I'm stuck. These are my fears. :( Any steps like that? I've never done this before.
  13. Azipod
    Azipod Member
    139
    NorCal
    You'll need the appropriate-sized socket wrenches to do the bolts on the strut-tower and the remove the bolts that hold down the windshield wipers along with several other bolts in that area. You'll also need a reg size flat-head screw driver to take off some clips and to remove the electrical harness connector for the windshield wipers. Finally, you'll need whatever tools you need to adjust and tighten up the strut-tower bar.
    It's pretty much just standard tools. If you have sockets ranging from 10mm - 14 mm I think you will be fine. Then just make sure you have whatever tools needed based on whichever strut-bar you decide to use. I believe the Sustec tanabe bar will require a Hex wrench to tighten the bolts that attach the bar to the strut-tower brackets.
    If you get stuck, you can always run to the hardware store to get what you need. The only thing that will be missing from your car will be the windshield wipers and the lower panel. You'll be fine as long as you don't do it on a rainy day! :-D
  14. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Mac - I agree with Azipod. I did the install myself on the Gen III. At first it is a bit daunting, but if you don't rush it, you'll be fine. Sockets are a must, especially the range that Azipod mentioned. And the Tanabe does require a Hex wrench (forgot what size though). I did review GadgetDad's DIY instructions, and they are very thorough! I know he used a torque wrench to tighten the bolts to the exact torque setting but that's being VERY thorough.
    Go for it man... think of this as your initiation into self-modding your Prius. You'll have a greater sense of self-accomplishment. :)
  15. a_gray_prius
    2,927
    782
    IL
    Does anyone have the C-ONE strut tower bar?
  16. macmaster05
    4,050
    729
    True. Every mod I've done has been relatively easy. Changing the fog bulbs. LED lights. Shark fin. Plastidip, lol.
    Tint and spring installation was done professionally.
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Azipod,
    The Toyota engineers did not skrimp. They used ultra high strength steel (which I have had personal injury free car totalling collision experience thereof).
    The problem with most high strength alloys is that the modulous is the same as lower strength alloys of the same base metal. So, if you design something lighter, out of stronger material, its done with less material. And the result is a more springy structure.
    Luckily these aftermarket bits and pieces resolve those issues.
  18. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
    OK...this post did it for me. I ordered mine. it was indeed $97 at EvasiveMotorSports, but the shipping was $33. I will let you know how it goes.
  19. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    My strut bar came in today and I won't be able to get it in until Saturday morning...I have a feeling I am going to be waking up early to get on the job.
  20. qmtran
    qmtran Junior Member
    87
    Seattle, WA
    You cannot really tell the difference w/ and w/o strut tower bars unless you are really pressing the car at or around 70% of its limit, ie racing it. Your chassis doesn't flex much at normal street and highway speeds. You might be able to tell over speed bumps, but that's about it for normal use. So unless you guys are going through turns at over 70+ MPH or hitting hairpins like no tomorrow, it is all a placebo effect.
