struts and shocks needed on 2012 V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dk_brookdale, Nov 4, 2021.
  1. dk_brookdale
    dk_brookdale Junior Member
    66
    I have a 2012 Prius V 5 with about 94,000 miles. Much of that driven over rough roads in my area. Last time I had a tire rotation the technician said I need new front struts and rear shocks. I've been shopping around for getting that service taken care of and I see a very wide range of what the cost would be for parts and labor. Anyone recently had that work done? About how much did that cost for you? I'm just trying to get some idea of what it should cost.
    Also, any recommendations on the brand of struts and shocks to use or what not to use?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,523
    6,604
    Texas Hill Country
    If they are not broke don't fix them. Were they leaking?
  3. dk_brookdale
    66
    It was reported by the tire guys that at least one of the shocks in back is leaking (didn't see it myself). When going downhill and encountering a speedbump or pothole there is a noticeable clunking/clicking sound from the front end.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I bought a Monroe Quick strut for a '12 Scion tC for our v, then never used it. (I got the idea because KYB lists the same complete strut for both). I also bought the parts that were listed that are different between the two applications on the Monroe website. It looked like the top mount doesn't even fit the shaft as my thought was to replace the different ones with the "correct" ones.
    The strut is stamped "Made in Japan" if you value that. Not 100% sure it will fit as I never tried it....
    REVVL V+ 5G ?
  5. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    I have been wondering about strut replacement. When my vanity tag was "Hondent" back in the 90's, I used to replace the struts every 80k miles, even though they never were leaking. Those "Hondents" had much improved handling after a new set of struts, and I felt it was $600 well spent. My 2013 Prius v has 104k on it, and the handling is OK, but the 2017 is a noticeably nicer ride with only 44k on it.
    I got married in 99, and wound up with a Dodge Neon and buying a Chrysler Voyager (Now refereed to as the "Jesus Chrysler"). I had a saved search on eBay to get a good price for compatible Complete Struts, and installed them myself on both vehicles. Not hard work when I borrowed my neighbors electric impact wrench. I then I would pay Sears for an alignment.
    I have hardly heard anyone mention strut replacement on PC, which has me wondering. If you have 240k on your Prius V, are you about to install the 4th set of struts? The Prius is a tough vehicle to get access to the strut towers. How long should struts last on a Prius v?.
  6. h-dogg
    h-dogg Junior Member
    44
    South Bay
    I replaced my front struts and rear shocks recently with KYB at 128k miles. They were probably still okay, but I wanted the front strut rubber boots replaced b/c they were torn. I am also riding on lowering springs, so that might wear out sooner. I changed the rears myself b/c it was easy, but had a shop do the fronts b/c there was more work.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  8. dk_brookdale
    66
    I might replace the rear shocks myself because that jobs does not look too difficult. Will probably need to get pro to do the front struts. While my V was up on the lift the tire guy let me have a look. The basis of his recommendation to get new struts was that the rubber boots were all torn up (same as what h-dogg commented above). Not sure whether or not torn boots would negatively impact the operability of the struts.
  9. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    My guess is that torn up boots would allow grit to get into the seals more easily, which would cause a failure sooner. If you buy what they call a "Complete strut" for a replacement, it isn't that hard to do. A "Complete Strut" comes with a new spring already installed, which eliminates the need to deal with compressing the old springs which can be dangerous. Plus you get strut cartridges that are tuned to brand new springs, rather than your old weakened springs.
    I think the hardest part is getting access to the tower bolts on top, which IIRC requires removal of the windshield wiper cowl. Usually it takes a lot of force to get the bolts that attach to the lower suspension off, but I have used my neighbor's Impact wrench. You need a full size torque wrench as well to put those bolts back on. You will need an alignment afterwards.
  10. Mendel Leisk
    41,911
    Over the decades, I've never replaced a shock or strut, well not due to wear. We did have front strut replaced on a Civic, but that was due to accident.
    Full disclosure though: I slow to snail pace over speed bumps.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I wish it were as easy around here, where you can peek in your rearview at someone TOO CLOSE or ANGRY.
    REVVL V+ 5G ?
    Danno5060 likes this.
  12. Mendel Leisk
    41,911
    It's not that easy here either. Another common trick of the lead-foots, to avoid speed bumps, is to drive over on wrong side, or through parking stalls. Keeps you on your toes.
  13. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    I however am an Uber driver in Philadelphia. I have to deal with a lot of speed bumps, but at least those are predictable, and they have signs warning you that they are coming. They also hit both front wheels at the same time.
    My bigger problem is potholes plus the unintended speed bumps that are caused by buses that stop on hot asphalt in the summer. These bumps are irregular, and they repeat as if they creating a "washboard".
  14. Mendel Leisk
    41,911
    If there's anything I hate more than regular, square-on speed bumps, it's diagonal ones; they turn you into a bobble head. I think we've got to talk some serious turkey with the "powers that be", about speed bumps, road salt, and... I'll think of more, when I catch my breath...
  15. ednorton
    ednorton Junior Member
    49
    delaware
    I thought you mentioned that mechanic said strut was leaking? In my view, just because the rubber is deteriorated, I don't think that's definite reason for replacement. I had a corolla with boots deteriorated, when I had120,000 miles. I drove car until it had 275,000 with same struts. If its not leaking and it passes the bounce test, and tires don't seem to be wearing unevenly, I would not change them!
  16. cruising gal
    cruising gal Junior Member
    27
    austin tx
    2014 Prius v wagon
    I hope it's ok to resurrect this thread?
    I have a 2014 V and would like to replace the strut/shocks - 175K miles, never changed and I'm feeling every single bump although the steering/braking seems fine.
    KYB seem to be either very expensive $214 at autozone or out of stock. Good alternatives? Munroe?
    thanks for your help.
  17. rjparker
    10,523
    6,604
    Texas Hill Country
    A Prius never was the smoothest riding vehicle and has almost no sound deadening. Generally the v rides better than the hatchback especially on the highway thanks to bigger standard tires and a v exclusive highway pitch and bounce control feature.
    How long have you had this car? Is it clunking on speed bumps or other slow speed bumps? Are the struts leaking? Is one corner of the car sagging?
    Struts are two pieces, a heavy duty shock absorber that really does not go bad unless it is leaking and a spring that could sag if old and worn. I have 265,000 on my v and it does not need struts. If I did need them I would buy oem or a top dollar aftermarket.
    One thing we know is Toyota factory parts are usually the best. Most aftermarket low to mid cost replacements are often 1/10th the quality and life.
  18. CLUBGUY
    CLUBGUY Member
    293
    50
    Cincinnati
    Rockauto shows KYB for Prius v for $74.00 each
  19. doctorman
    doctorman Member
    210
    36
    NY 11020
    2012 prius v with under 80k miles
    So is there anything I can do to improve the ride? especially speed bumps and potholes. it would be nice not t feel them so much
  20. rjparker
    10,523
    6,604
    Texas Hill Country
    The best thing is good tires inflated no higher than the door sticker. Struts won’t help unless they have leaked out their fluid.
    My 2012 v3 has original struts at 310k miles. I like Michelin for ride and tire life of 90k-100k miles. 16” wheels are better than 17” for ride.
    #20 rjparker, May 30, 2024
    doctorman likes this.
