stuck 2 wire connector to coolant storage/drain for drain/refill
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by thomassster, Feb 13, 2016.
  1. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    i have a 2007 prius and this is my first time trying to do a coolant drain/refill. I'm at the point where I have access to the coolant drain. I'm trying to remove that 2-wire connector that is next to the drain, but I can't seem to remove it. What is the trick to removing it?
  2. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    USUALLY you have to squeeze a small tab on it to release but can you upload and post a close PIC of it?
    thomassster likes this.
  3. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    Just did what you said. I pushed the tabs and it loosened. Thank you very much.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Often those plugs are the harder part of working on modern cars. Last valve job I did I had to figure out how to unplug about ten connectors, all different, and it took about ten minutes, often a paperclip or tiny screwdriver, and a third hand for each. The actual wrench work took less time than that.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Why on you trying to remove the water temp sensor?
  6. andrewclaus
    993
    326
    Golden, CO
    He pulled the plug for the CHRS pump motor, next to the coolant drain. The instructions I followed in my Bentley book had me do that, too.
  7. Patrick Wong
    18,200
    6,500
    I do not know why that would be necessary. What does Bentley say about the procedure to drain and fill the CHRS canister?
    edthefox5 likes this.
  8. andrewclaus
    993
    326
    Golden, CO
    I don't know why, either, but it looked official so I followed the step. Much of Bentley's detailed instruction, what little there is, seems to exactly follow Toyota's procedures. I assumed it had something to do with keeping the OBD system happier during the procedure. Maybe it returns the three way valve to a certain position.
    I'm not sure I understand the question, and right now the book is loaned out anyway. Is there a need to drain and fill only the canister, without draining and filling the whole system?
  9. Patrick Wong
    18,200
    6,500
    The Toyota service procedure includes a step to connect the CHRS pump connector. However it does not include a prior step to disconnect that connector. It also uses Techstream to run the CHRS pump motor.
    As a practical matter, I see no reason to disconnect the pump connector as long as the car is IG-OFF when you are draining the engine coolant.
  10. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I saw the instructions on the YouTube video from JasonReed. He stated to remove that connector. I didn't question whether it was needed but I figured it didn't hurt to do it. I see now that removing that connector probably wasn't needed.
  11. andrewclaus
    993
    326
    Golden, CO
    Well that's odd. Maybe the Bentley crew, in their wisdom, saw fit to add an apparently missing step. Perhaps it's a compounding of errors. Maybe the Toyota procedure has an extraneous step, an editing mistake, and nothing needs to be done with that connector after all.
  12. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Well...the main issue is for a first time FULL coolant drain its a real pia to get the air out. I did it and won't do it again. Its tough because of the CHRS.
    In my very humble opinion your much much better off just dumping the rad once a month for a few months. That really helps.
    Much safer than exposing your cars engine to an overheat from a poorly performed change. Seen so many posts that even the dealer messes it up. I wouldn't try it without at least a Scangauge to monitor engine temp.
    If the op continues on a full dump don't forget the engine dump bolt. Its under the exhaust mani.
    Btw, the engine coolant lasts a long long time. Your much better off putting that energy into changing the Inverterr fluid. Its quite easy and a breeze to get the air out and you get an instant bump in mpg's. The Inverter is the heart and soul of this car. Happy Inverter Happy life.
    I do mine every 30K miles when I do my trans fluid and evap coil cleaning.
  13. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    my car is at 150k miles, but it did got change one time around 75k miles. The difficult decision is deciding how long is long for a coolant change. I did look at my coolant and for 75k miles, it didn't look that bad.
    When I did the change, I used the lisle spill free funnel which probably helped out a lot since I just kept on pouring and made sure the funnel always had coolant. After couple runs with car on and off and no more bubbles, I thought I was good.
    The bleeder valve really sucked though since I had a 3/8 OD 1/4 ID tube and I opened up the bleeder couple times. Some coolant went in the tube and some just spilled right out. Even with a tie wrap, it wasn't tight enough to keep it sealed.
