1. chrisintheprius
    chrisintheprius Junior Member
    southwest Virginia
    I just started hearing a ticking sound in my drivers side rear wheel. It sounds like a pebble in the tire at low speeds and as you get faster it makes loud road noise in the car, almost like a whoosh whoosh sound. Took it to a local auto shop and they said it was a stuck brake caliper and possible wheel bearing. After driving I felt each rotor and that one was considerable hotter then the others. Everything else about the car is fine, drives well with no vibrations and brakes well. Jacked the wheel up to see if the wheel was loose from a bad bearing, but it was not loose. The shop, however, can not locate a caliper saying it was on national backorder. Does this sound like a bad caliper and is it normally hard to find parts? I'm trying to avoid going to a dealer because of price, but that maybe may only option. The car has 90,000 miles.
  2. tv4fish
    tv4fish Member
    202
    46
    It sounds like a "sticking" caliper - as in it is not releasing after you let off the brake pedal. Have you done a "brake job" before? It isn't that hard - and, NO - the parts should not be that hard to get - the Internet is a great tool :)
    52,524
    welcome! is it front or rear? when you turn the wheel by hand, is there more drag? i would check with parts.com for a caliper, or, it may just need to have the slide pins lubed. all the best!(y)
  4. ChapmanF
    18,705
    You might not want the caliper the shop was going to put on, anyway.
    It does sound like that brake is dragging, which can always be caused by slide pins not sliding easily, or the piston not retracting properly; in addition, for a Prius rear, there's the third possibility of the parking linkage binding somehow. These are all things you can check and probably correct while keeping the caliper you have. (Slide pins are the part you can attend to without disturbing the hydraulics; delving any deeper will require the ability to bleed air from the brake when you're done.)
    Shops these days avoid spending any more time than it takes to bolt in a reman caliper and send your old one away to be cheaply remanufactured itself.
    I just recently learned a lot about quality in reman calipers ... the hard way.
    Two things about Toyota's calipers: (1) there's a shocking price difference compared to generic remans, so it would take a shocking quality difference to persuade me they're worth it ... and ... (2) I am persuaded. I'm now on the same page with the classic Porsche restorer dude: "... adamant about getting the proper caliper on your car. There's a good chance those are the calipers you have on your car..." (assuming, of course, those are original, and not already replaced with something else).
    Now that I've seen what I've seen, my first choice (if your caliper casting looks sound and undamaged and is still keeping corrosion at bay) would be to go totally old-school and get the rebuild kit for it. Even from Toyota that's just $25 for all the stuff do to both sides, even down to a little packet of the proper rubber grease. You could spend still less than that on 3rd-party rebuild kits, but ... dude.
    Then just sit down with any of the online howtos and videos and restore the proper function of the caliper you've got.
    One caution: at least going by the illustration, the kit does not include new seals for where the parking linkage goes through, so if that ever leaks, it might be necessary to replace the caliper. (Or maybe if you buy the kit, you'll find it really does have those seals too, just left out of the illustration.) But other than that, you'll end up with the dragging problem fixed, little money spent, and original-quality parts still on your car.
    I strongly recommend testing the caliper after rebuilding—or any replacement caliper, even right out of the box—for proper piston retraction, as I described in my other thread I linked to above. It's an easy test (doesn't require shop air, a bike pump should be adequate) and calipers I've tested from Toyota return by a good 0.3 mm or so when you release the air; it's visible to the naked eye. The (non-Toyota) reman I first bought would have failed that test right away, and saved me the trouble of installing it and driving around for weeks wondering why it still seemed like my brake was dragging. :(
    -Chap
    Edit: just to be clear, your Gen 3 caliper is probably aluminum, so the exact details in my other post about the finish used on the cast iron obviously won't apply, but the other points should stand.
    #4 ChapmanF, Aug 24, 2015
  5. chrisintheprius
    southwest Virginia
    Thanks for all the replies it has been helpful. If I do need to replace the caliper should I also replace the caliper on the other wheel?
  6. ChapmanF
    18,705
    What you definitely want is to make sure both calipers work:
    • they clamp when you brake
    • they unclamp (by about 0.3 mm) when you release brakes
    • they slide freely on their pins
    • they don't leak fluid
    As long as you can say those things are all true on both sides, the calipers are as they need to be. And in almost every case if those things aren't all true, you can make them true simply by servicing the calipers you have. Replacing a caliper unnecessarily is expensive if you use a $200 real Toyota part as the replacement, and cheapens the car if you don't. (Ok, that's a personal opinion of mine, but it's one I didn't have before I had the need to compare up close.) Keeping the originals in good shape with the $25 servicing kit, when you can, is a good value-conserving move. If the other caliper is passing all the function tests with flying colors and you don't feel like fussing with it, just hang onto the other half of the parts in the kit until you do.
    Cases where you might have no option but to replace the caliper could include real, deforming, physical damage (as in a crash), or severe corrosion. (On my calipers, the piston is metal, and could get rusty if the rubber boot tears and lets salt water in. I think your pistons might be phenolic and might not even be damaged in that case.)
    Examples of changes you do want to always make on both sides simultaneously would be anything changing the friction surfaces. New pads, new rotors, lathing the rotors, hand sanding to take off surface glaze ... any of those things you'd want to avoid doing to just one side, or the friction properties wouldn't be matched.
    As for the calipers themselves, their jobs are simple enough that as long as they both work (per the four points above) it's fine. If one is working fine and one isn't, and you fix the one that isn't, then they both work, and it's fine. :)
    -Chap
    johnHRP and CR94 like this.
  7. A_P
    A_P New Member
    Michigan
    I have a 2010 with 85,000 miles. Recently replaced the front wheel bearings but have since come across a thump sound. Thought I installed the bearings incorrectly; after putting a second set of front bearings on, new struts, ball joints, and tie rod ends...still thumped. Thought the rear bearings were going, replaced those...still thumped. Finally found a frozen caliper pin on the rear right and thought I found the problem. Replaced both calipers, new pins, etc, still thumping. FINALLY thought to just feel the rotors after driving, the left rear is hot, other three are cool. So I’m dragging a rear left brake but can’t find the problem. I bled the system without issue and the parking cable looks fine. When I find the answer I’ll post a follow up.
  8. Mendel Leisk
    42,041
    @A_P when putting the rear brakes back together, make sure the piston caliper is oriented like this:
    The shaded areas are raised "spokes", and it's important that the stubby pin on the pad backing plate is in between the spokes. It locks the piston, prevents it from turning when the parking brake is applied. If the pin is not in between the spokes, or manages to slip and ride up onto a spoke, the brakes WILL drag, be hot, wear the pads unevenly, score the rotors, and on and on.
    If the inside face of the rotor is about 50% rusty, that's very likely what's happening. If the rear end's raised and the wheels spun by hand, they should go a revolution or two after you let go.
    The key is to get the caliper piston orientation right when reassembling, then tromp the brake pedal multiple times, to get it seated.
    Then hook up the 12 volt negative cable (best to disconnect at the outset), do a test drive.
    When you get back, apply/release the parking brake brake a few times, raise the rear, and check the wheel spin. If they're spinning relatively freely you're out of the woods.
    scona likes this.
  9. ToyotaCoyotta
    ToyotaCoyotta Junior Member
    56
    Lithuania
    have you found it ?
  10. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    The answer is no. However, you need to check the other calipers and add silicone grease on the sliding pins. Clean the surface where the brake hardware (stainless steel) meet the bracket. Clean it really well and add some Copper paste there to prevent it from rusting and jamming the pads.
    I always recommend to change the discs and pads at the same time whenever the calipers stucks. Especielly if it is the front brakes.
  11. ChapmanF
    18,705
    Toyota specifies a glycol-based, lithium-soap-thickened grease for those pins and also the piston boots and seals (consistently, over years, even while selling packets of silicone grease for use elsewhere on the brakes). The glycol grease is a clear red color and they include a packet of it in every caliper rebuild kit. (A full tube of the stuff is called "rubber grease" with their part number 08887-01206, but you might never need one if you use the packet in the rebuild kit.)
    There are people on PriusChat reporting using silicone greases there instead, and not reporting problems, but it seems only fair to make sure the Toyota spec is mentioned too.
  12. johnHRP
    646
    189
    KA, DE
    Excel
    That's a lot of works and parts. The ball joints never fail in Prius. I learned now to pay a professional for diagnostic before replacing things. Thumping sound is more like missing rubber damper instead of brake. It is good that you cought it.
    Check the rear seats back rest. Insert a used bike inner tube and it maybe it. I also chased Thumping noise on uneven roads. I replaced the expensive rear stabilizer links 400€ parts alone in my Auris 2016 hybrid, removing a lot of panels on the body, but nothing changes. Until I found that the sound is only when nobody seats on the back.
  13. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Youd make a ton of money if you opened a shop!!
    johnHRP likes this.
  14. johnHRP
    646
    189
    KA, DE
    Excel
    Not really, I make more money by doing BS in the University :ROFLMAO::ROFLMAO:
