Stuck in non-moving traffic, went from 6 blue bars to 2 purple bars in 10min.
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jul 4, 2020.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    Yesterday I got stuck in non-moving traffic on the Hwy.
    With the A/C ON=The Prius went from 6 blue bars to 2 purple bars in 10min. - IS THIS NORMAL?
    ….After traffic started moving again- it jumped back to 6 blue bars again after a few minutes of driving
    Data Daedalus likes this.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Pretty typical, especially for a older hybrid.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    With the AC on, that's normal;).
    Data Daedalus and MickyMatter like this.
  4. cthindi
    cthindi Member
    177
    85
    Connecticut
    If it took 10 minutes with AC on, I would say that is not bad for a 12 year old car.
    Engine typically comes on when you go to 2 bars.
  5. JerryScript
    JerryScript Junior Member
    43
    38
    I spent an hour in below 10mph traffic yesterday, lots of stopping, and just creeping along while leaving a fireworks display at Buffalo Springs lake in West Texas. What you describe is almost exactly what I experienced as well. Outside air temp was still in the low 90s at 11:30 during that crawling exit! I was nice and comfy with ac set to 76, and once I cleared the traffic, the battery got back up in the 5-6 bar range for the rest of the trip home.
  6. bisco
    51,933
    what was the temp and dewpoint?
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    The AC compressor runs off of the HV battery.
    Along with the power used to just creep along in EV mode, why would you think that this is unusual ??
    It isn't.
    10 minutes is a long time.
    Data Daedalus and JerryScript like this.
  8. PriusCamper
    PriusCamper Senior Member
    12,764
    5,173
    Pacific Northwest, USA
    Used to have the same problem before reconditioning my battery pack... Basically as these packs age they lose capacity due to crystalization issues inside the pack. You break up that crystallization by doing three increasingly deep discharges and recharges. In most older Prius that will restore a battery running at 50% capacity back up to 96% capacity. The science of it is here: BU-807: How to Restore Nickel-based Batteries – Battery University
    And the gear to do the work without pulling the pack out is here: hybridautomotive.com
    Raytheeagle likes this.
  9. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    For a 2nd Generation Prius, that is indeed perfectly normal. I’ve experienced similar. It does depend on many factors, including how hot it is (both outside and inside your vehicle) that specific day, how long you’d been driving, whether your A/C was on auto or manually set to “minimum life support”, and the TRUE state of charge of your traction battery when you encountered the congestion.
    You’re more likely to encounter this phenomenon in hot weather - but, it’s perfectly normal.
    Note that even at the purple bars, you’ve still got about 40% state of charge on the HV battery.
    Perfectly normal.
    iPhone 6s +
