stuck/stiff rear ABS speed sensor harness connectors (Gen 2 Prius)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by utterprius, Jul 22, 2018.
  1. utterprius
    utterprius New Member
    Ithaca, NY
    I have Techstream codes suggesting problems with my left and right rear speed sensors.
    In the hope it is something simple, like some corrosion in the connectors, I am trying to disconnect and inspect.
    I am trying to pull the connector loose but neither will budge. I am wary of pulling or prying too hard in case I damage them.
    Does anyone have any experience of this, and is there a specific technique? Or should I just pull harder?
    Thank you!
    SFO likes this.
    49,586
    is there a clip on the side? maybe try pliers on both sides and wiggling?
  3. ChapmanF
    15,777
    I believe the retainer on those may be designed to be worked with a screwdriver. Check the manual ....
    -Chap
