"Stuck" unlock button-will SKS work with dead FOB battery?
Discussion in 'Gen 2 Prius Main Forum' started by drw, Aug 10, 2010.
  1. drw
    drw Junior Member
    31
    Yesterday when I pulled in my garage, my 2007 Prius starting locking over and over by itself- it was freaking me out.
    In doing some internet research and on here, I realized that my unlock key was “stuck†and could not be pushed in, and I assume this is what was causing the automatic unlocking. I have played around with it, but so far I have not been able to open it up or pop it back in place as some have been able to do.
    A couple of questions:
    I think this has caused the battery to die on my FOB, because none of the buttons work now, and the red light doesn’t flash when a button is pushed. But, the smart key system still works, the doors unlock when I touch the handle, and I can drive the car. Will that continue to work with a dead battery in the key FOB??
    Has anyone who had this problem been able to get a free replacement if you are out of warranty?? What bugs me about this is I NEVER use the buttons on the FOB- always use the smart entry, etc, so I know I didn’t do anything to cause the unlock button to stop working……
  2. chuckknight
    chuckknight New Member
    194
    33
    Officially, you're out of warranty. Toyota doesn't owe you anything. Sorry.
    Unofficially, if you find a nice person at your local dealership, they may help you out. A stuck button doesn't mean that the fob is dead...only that it has a problem. Unsticking the button may be all that is required. I've been known to unstick a few buttons on keyboards, before, so it's possible.
    Replacement fobs are quite pricey, so do try to make nice with the guys at your local dealership. It's in your best interest.
  3. drw
    drw Junior Member
    31
    Thanks for the reply- the reason I think the FOB battery is dead is the other buttons don't work either, and the little red light does not flash when pushing a button.
    So, does anyone know if the SKS (touching handle to enter car, starting car without putting fob in slot) will continue to work with a fob that has a dead battery? Because mine is still working right now with a fob that I think has a dead battery
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    If the button is still stuck down, that is why the the other buttons don't work. It can only do one thing at a time.
    As far as I know a dead battery will render the SKS inoperative. You will have to insert the FOB in the dash.
    I'd take the FOB apart and fix it, and while you're in there measure the battery with a voltmeter and replace it if it's dead. It's a very common battery.
    Don't try to use it with a stuck button!
  5. drw
    drw Junior Member
    31
    Thanks- I have confirmed that the battery is not dead- I put a fresh one in there and none of the buttons work- but all of the SKS sytem still does- so is there any harm in continuing to use it this way if I can't fix the stuck button???
  6. David Beale
    5,963
    1,985
    Edmonton Alberta
    If it works it works. What can I tell you? ;)
  7. chuckknight
    194
    33
    A stuck button means that the fob is constantly broadcasting a radio signal. That means super short battery life, compared to normal.
    Did you contact your dealership, yet? I would try to talk them into fixing it for me, before I pry it open and try to fix it myself...after my own attempt, they could *rightly* blame its failure on my own meddling in the "non user serviceable" key fob.
    Call them.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you have an 07.. the rubber buttons in your fob is more of a layer. you can pull the rubber off from the plastic and essentially pull off the button pads. it has a lip around the button pads that locks into the fob...
    this means if you use a butter knife or screwdriver, you can pull rubber from the fob and place it back into the fob gently. (non pushed down)
    if you're a DIY type of person.. you can even apply tiny amounts of glue and glue it back in.
    if i confused you.. i'll take pics. (my old fob had the same problem).. my new fob is still factory glued so i don't need to abuse it yet.....
    jcr likes this.
  9. jcr
    jcr New Member
    Detroit, MI
    I was successful in getting my unlock button unstuck by partially removing the rubber cover as described by CobraKid in this thread Unlock Button on Fob Stuck Down | PriusChat.
    The entire rubber strip has a ridge/lip that holds in onto each button hole. The black rubber cover has embedded white plastic bits that push on the actual button switches on the circuit board beneath. The white lock and unlock icons on the cover are actually the front side of these plastic bits.
    Go slowly and be careful. It is easy to overstretch the rubber by pulling to hard in one spot. I used needle nose pliers, after I got it started at a "Lock" corner with with a fingernail. However, with the benefit of retrospect, it would have been better to use a spudger tool (sort of like a dull plastic flathead screwdriver) to push the ridges inward just under the edge of the rubber.
    There was no visible glue, but it is possible it is glued in some places. It is pretty stiff to dislodge and remove. After I got about 80% of the lock button portion up, and maybe only 30% of the unlock button unsealed, the unlock button popped up and started functioning properly again (tactile button response). I then put the rubber cover back in place, kind of rolling the last corner inward a bit so the lip beneath the edge would catch properly on the hard plastic underneath. Other than a slight distortion in rubber that has the shape of my needle-nose pliers, it seems to be good as new.
