Study Ideas - Battery Degradation
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jun 20, 2017.
  1. markabele
    5,084
    1,782
    Nebraska
    I'd like to get some data to take a look at battery degradation in our PiP's. So I'm coming to you guys for some ideas!
    In an ideal world we would have everyone get the Torque app and check every last battery detail over time. But if that were the case we might not get any participants. So we probably need to go with something very basic that anyone on this forum can check. Obviously the starting range number is the very easiest way to do a battery check. But we all know this number is a complete guess from day to day. But if we had a ton of data points I believe all those variables become less relevant. Any thoughts on that? Or other data points that would be easy to get for the average driver?
    The goal isn't to have the absolute best, most scientific study, simply one that can give us a good idea of how our battery degrades over time. Thoughts?
    Aaron Vitolins likes this.
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Your study should probably account for driving climate, too. All through the winter battery power looked bleak, but with the warmer weather my electric range automatically increased by 2 miles.
    48,974
    i think someone said to measure the charge amount from empty. the more it takes, the healthier it is.
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Mine's empty now and a tiny bit into the hybrid portion. I can let you know what the killawatt meter says after it charges in the morning. Most days, though, I still have a mile or so left when I stable it for the night. But I have no comparison to when it was new. :unsure:
  5. jerrymildred
    11,491
    14,100
    Tampa, FL
    I'm back with my hyper-preliminary report. I had forgotten that my previous charge was not at home, so I couldn't just subtract the previous reading on the killawatt meter. But, in looking over the numbers, I would estimate it typically takes about 3.3 kWh for a full charge. I would have to do two full charges in a row at home (rare) or else take my meter with me to work to be more precise. I'm reluctant to do the latter since my outlet at work is outside and it's been raining every day here in the Sunshine State for the past several days.
  6. QuantumFireball
    QuantumFireball Active Member
    416
    267
    Ireland
    But what's "empty"? Once EV mode disengages (around 23% SOC) then it's running in hybrid mode, and the ICE starts immediately which changes the SOC again. In a recent long journey I took in 100% hybrid mode, the SOC varied between 18-26%. I just don't think there's an easily achievable point of reference here.
    Measuring energy consumption at the mains also needs to take into account loss in efficiency, and differences in efficiency of 100-120V vs. 220-240V charging. A lot of "smart" meters are also woefully inaccurate...
  7. bisco
    48,974
    it doesn't really matter where empty is, as long as you test it the same way every time. you could start from .1 left on ev, but even if you run it into hybrid mode, long term testing should show any major degradation. hybrid segment of battery is pretty small, and generally maintains between 4 and 6 bars.
    but you might be right, i haven't done any testing myself. someone here had their whole charging history graphed out. maybe in the battery degradation thread.
  8. jerrymildred
    11,491
    14,100
    Tampa, FL
    Are you referring to post #42 here? Good memory!!
    Electric battery degradation | Page 3 | PriusChat
    bisco and markabele like this.
  9. bisco
    48,974
    yes, thanks! and check post #38 as well.
  10. jerrymildred
    11,491
    14,100
    Tampa, FL
    So, it looks like mine is taking a little more than giora's was back then. But then I have more charging overhead since he's in Europe and presumably using 220 volts.
    I do want to try some experiments of measuring full charges. I'm convinced that's the most accurate way to measure capacity. It's not perfect because you will have to work really hard using a scangauge or something to have a consistent soc when you begin charging. Using the estimated miles is more a measure of the driver's efficiency skills and the driving conditions. I have no way to know what mine was when new, but at least I'll have a baseline for myself.
    bisco, Mendel Leisk and markabele like this.
  11. jerrymildred
    11,491
    14,100
    Tampa, FL
    I have some hard numbers now, but not many. I ran HV down to 0.1 miles and did a charge. Next day, I used it all plus a little and did a charge. Here's a screen shot of my spreadsheet. I showed the formulas in the right column. Does this look like good methodology? I wasn't sure what to use for overhead to account for the difference between what the meter sees and what the battery actually gets. It shows a lot more extrapolated capacity than I expected, but 15% overhead also seems like quite a bit.
  12. bisco
    48,974
    looks good to me. does the 'overhead' matter, when your just trying to determine long term capacity reduction?
  13. jerrymildred
    11,491
    14,100
    Tampa, FL
    Good point. We're just looking for a trend and overhead should remain constant. It would influence the percentage of degradation somewhat, but not the amount in kWh.
    Edit to add: I will try to get another reading today to get a broader baseline. I Have been recording meter readings, so I might make another sheet to list and graph them.
  14. markabele
    5,084
    1,782
    Nebraska
    I charged the first time in a long time from "zero" to "full" on my 2013 (110k mile) PiP using a ChargePoint station. What was extremely disturbing (if true) is that it only took 2.447 kWh to do so!
    And the math tells me it's true based on my mile/kWh stats that I have and what I usually get out of a charge. This is a 28% drop from the original 3.4 kWh!
    How is this number stacking up to other people's?
  15. bisco
    48,974
    why don't you post it in your other thread where jerry mildred has been doing yeoman's work on testing.
    markabele likes this.
  16. markabele
    5,084
    1,782
    Nebraska
    Just went from "empty" to "full" on a ChargePoint charger and it said I only added 2.447 kWh. That is disgusting and sad.
  17. bisco
    48,974
    hard to believe mark, how many miles of ev are you averaging?
  18. markabele
    5,084
    1,782
    Nebraska
    I'm averaging about 13 or sometimes 14 if I drive really careful. Keep in mind I'm a very slow/experienced hypermiler. My stats show that I usually average about 5.3 miles/kWh so this number would support that sad total kWh as well.
  19. markabele
    5,084
    1,782
    Nebraska
    fyi that's a 7.7% drop per year
  20. markabele
    5,084
    1,782
    Nebraska
    it's a 7.7% drop per year
