Stupid question: How you can plug in inverter?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by madmarc, Apr 26, 2011.
  1. madmarc
    madmarc Junior Member
    Graz / Austria
    Stupid question: How you can plug in the inverter direct?
    So I've done some research, and the prius has AC-DC converter in his inverter integrated.
    AC is 200-500V , for us in europe it is no problem we got 360-400V with 3 phase.
    The question is, what happens when I connect my prius with my normal eletric power source?
    Has anybody tried this?
    How I know, U V W phase?
    It should work, when I disconnect MG1 oder MG2 and the wheels can spin free and I put D in.
    Cause in D the car can recupate, without one of the engines or both disconnected, the engine also doesn't spin and the electronic should charge the battery, cause of the household electric sourve connected.
    I think the Prius 3 plugin prototypes from toyota use the same princip.
    May someone can help me, I not so good at electronics.
    Thanks
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    Let me see if I understand the question. You would like to plug three phase mains directly into the inverter in order to charge the HV battery?
    Please don't do this.
    It is generally highly discouraged to charge the HV battery by any external means. Some people have built special HV power supplies, or used old physics lab HV power supplies, to charge their batteries, but the risk is high relative to the benefit. If you are very, very serious, then you should look into an aftermarket plug-in conversion of your car, or sell your car and use the money build your own electric vehicle.
  3. madmarc
    Graz / Austria
    yes correct I want to use the car's inverter for chargin HV batterie.
    I think the idea is not so bad cause when the car brakes you also have voltage and much more current then at a household plug. And all savety features for the HV batterie are turned on, cause the car is running, so the BMS of the prius is active, and does what he means it it best for the battery. For the car it looks you roll and you're recupating.
  4. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
    I'd like a way to use my car as an oversized boom box without having the ICE turn on. I buy and sell cars for fun, and I'm often caught parking the Prius on the grass, playing music (because it's got the system I put in it) when I fix up the cars for selling. I don't like that it has to constantly recharge the batteries by running the gas engine.
    I tried using a float charger on the 12v in the back on several different settings, even going so far as to leave it on FAST CHARGE and START (as if to quickly jump start a car). It didn't seem to do anything as far as I could tell. The car would still run every so often to charge the battery.
    Maybe I just need something stronger?
  5. madmarc
    Graz / Austria
    problem is in usa you only have 110V at 2 phase, so at 3 phase it should be 165V, that is to less for the prius. The prius should have 200-500V.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    Toyota's plug in approach is having a separate HV charger.
    That's the answer.
    Ken@Japan
  7. madmarc
    Graz / Austria
    Prius 3 plugin uses second charger, cause of the li ion battery pack.
    Prius 2 plugin, i didn't see and find nothing about a second charger.
  8. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    So, you didn't see a separate HV charger on the Gen2 plug in.
    I saw it on the Gen2 plug in.
    That's difference.
    Ken@Japan
  9. fuzzy1
    10,335
    Any 2 phase remaining in the US is legacy industrial equipment from nearly a century ago. Standard residential service is split single phase in the range 110/220 to 120/240.
    But through the magic of transformers, the raw voltage doesn't matter. EV / PHEV battery chargers can be built to operate from either voltage range. But I'm not aware of any current vehicles that can allow the AC mains be tied directly to the motor drive system without killing something or someone.
  10. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Markus,
    This has been tried (pEEf has tried) and it does not work, the Prius will throw an error code, as it is not expecting the power on the HV bus.
    If you have a rectifier to turn 230V AC into 230v DC you can connect this directly to the HV battery, this is how the Enginer system works (230-240V DC connection). You must sit with the car while it charges, and the car must be in Ready.
    You say you are not good at electronics. if that's true, don't do anything like this, as you could either kill yourself or destroy your car.
  11. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    I basically just asked same question a few days ago and was quickly talked out of attempting it by people who have tried. So I opted for a enginer 4kw system I would recommend instead of trying to do this and waist time and money and possible harm to you or your vehicle to just buy a phev kit.
  12. BrettS
    BrettS Active Member
    290
    136
    Orlando
    If you're actually turning the car on (with the Ready light on) then you won't be able to prevent the ICE from starting to charge the HV battery. The climate control (if it's on) and other systems take power from the HV battery and when that gets low it will start the ICE to charge the HV battery. Putting a charger on the 12V battery won't stop this from happening.
    However, if you put the car on in Accessory mode (hit the power button *without* your foot on the brake) the ready light will stay off and everything will run off of the 12V battery. If you run like this for too long you could drain your 12V battery and prevent the car from starting, but in this case, putting a charger on the battery with enough power to run the radio will let you run indefinitely without it running the ICE.
  13. richard schumacher
    7,664
    1,043
    United States
    *Don't* do that! Prius' inverter creates pulsed power of variable frequency to control the motors; it never generates anything that looks like mains power. If you connect it directly to any mains supply it will immediately be destroyed.
    It's fun to think about such projects but successful plug-in conversions depend on the details. All of them create DC power to charge the HV battery, and require very careful monitoring of the battery to avoid over- and under-charging. A home-brew attempt that doesn't do everything correctly will destroy the HV battery or harm the person doing the work.
