Sub installation: line in to amp??
Discussion in 'Gen 2 Prius Audio and Electronics' started by krooster1234, Aug 17, 2004.
  1. krooster1234
    krooster1234 New Member
    72
    Glenview, IL
    I'm going to be installing an amp/sub in my 2004 prius, which has the JBL system. I have one question though:
    What are my options for signals that I can run into the sub amp, and where are these signals easily accessable?
    I've done searches of this forum, and the only example I found where someone gave specifics is where their installer used some sort of device to convert the signal going from the JBL amp (to the rear woofers) into a pre-amp signal.
    I was hoping there was an easier solution.... like access the signal going from the head unit to the JBL amp, and wire it to the amp for the sub??
    Basically, I just want to know what kind of signals an aftermarket amp can take as their input, because I know you can't simply take the line out of the JBL amp and use it as the line in to the sub amp.
    -Kevin
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The line-in for the amp is a shielded 4 conductor wire. The receiver only outputs 2 channels, and fade and balance (and possibly volume) appears that it could be handled at the amp itself via an ACV-LAN connection (which btw, kills anyone's idea of putting in an aftermarket amp). There are also 2 mute lines - one for the NAV and the other probably for the head unit itself.
    The line-in connection at the amp colors would look like:
    Common Shield connection
    Left (-) = Black
    Left (+) = White
    Right (-) = Green
    Right (+) = Red
    Because this is not faded - and possibly not volume controlled (fixed output), it may not be a reliable source for input. Also, we don't know the impendance or voltage of the line-out, which may or may not match your sub amp's requirements.
    Although it's not the best option for fidelity, I'd opt for the speaker-to-line converter off the rear speakers simply because I would know it's post-modulated (volume, fader, etc.). And given that it's a sub, I wouldn't be worried about killing high-end fidelity.
    For those with techinfo access - grab the "Multi-Display and Audio System with Separate Amplifier" file and you can have a better understanding of what I'm talking about. Filename 052mdass.pdf. This file also shows how it connects to the multi-display unit (screen) and whatnot.
    For those without, I've taken the liberty of taking some screen-shots (PNG format) of the 2 pertinent pages - Danny if this isn't kosher, feel free to pull them. They tell way more than I can describe, however the connections displayed are not all-inclusive.
    Enjoy!
  3. krooster1234
    72
    Glenview, IL
    Thanks for the excellent info.
    Also:
    Does anyone know for sure whether or not the line into the amp is volume controlled, or whether the volume control takes place in the amp? Using the signal going to the amp would be preferable, if volume control is possible.
    Does anyone know if I can just go into an audio store and ask for a "speaker to line converter", and they will be able to sell me one? Do I need to know any specifications of the amp to find the correct converter?
  4. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Can't answer the 1st question, I have the #7 non-JBL stereo...but the second I can. Sure, the device you're looking for is commonly called a line-out adapter. It takes the high-level speaker signals (say, from a head unit or even right from a speaker), then lowers it thru circuitry to 'amp-level' signals, which an aftermarket amp likes much better. I don't believe there are any specs one has to know to do this. Also, get the best u can afford, helps in a clean solid signal with minimal loss. I'm hoping to add a sub to my basic system someday, running the rear speaker signal thru a line-out adapter and into a sub amp. Got to have more bass! Love this car...
