Featured Subaru PHEV coming later this year using Toyota Prius Prime tech
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by royrose, Feb 9, 2018.
  1. royrose
    royrose Senior Member
    1,389
    951
    Foot of Pikes Peak
    49,693
  3. austingreen
    austingreen Senior Member
    13,591
    4,132
    Austin, TX, USA
    hmm. Like the idea. In today's market a phev and hybrid suburu wagon/crossover will likely sell better than the prius v, and toyota may make more money off the parts then they would off the v.
    Subaru and Porsche are the only car companies using flat 4s. With porsche, they started because they are better for air cooling (or oil cooling ;-), and give a low cg. For front wheel drive, the packaging doesn't make sense, so everyone trying to share 4 cylinder engines with fwd cars has gone to an I4. The flat 4 does work well with the subaru awd system. Given time to develop, I'm sure subaru can develop a good psd to replace part of its transmission and work with the flat 4 for a hybrid.
    This doesn't make sense in a phev though, with its bigger battery, it doesn't make sense to keep all that weight from the awd transmission. Volvo has through the ground awd, Tesla D or dual motors, and toyota has their mg3 system that they use on the rav4 and highlander hybrids. IMHO the only problem with the toyota system is the motor and battery aren't sized big enough to give enough power, but suburu engineers can fix that fairly easily. My guess the best way to get this phev on the road is use the primes cells and software and maybe even its engine and psd + an mg3, but size the motors and power electronics to act more like subarus awd system. Choose the biggest battery that will fit the chassis using those cells. Trying to get that boxer engine to work with toyota's psd, seems tough, and not the best implementation of this car. Maybe once subaru figures it out for a hybrid the phev will come naturally. It will be interesting to compare the subaru phev in hybrid mode with the rav4 hybrid.
    scona and RCO like this.
  4. Trollbait
    11,632
    Sounds like they are keeping the flat 4, and while Toyota has the best odds of being the hybrid system supplier, it isn't confirmed at this point.
    Subaru could go with a parallel hybrid. Such would be easier to install with their existing transmissions and AWD. Not the best for efficiency, but it will help with costs. Long odds is to have the engine drive the rear and have a couple of motors up front. A flip of Honda's Sport Hybrid AWD.
    austingreen likes this.
  5. bisco
    49,693
    price will be interesting.
  6. dipper
    dipper Senior Member
    1,242
    252
    Toyota and Subaru have a flat 4 on their rwd car partnership. Maybe similar to Porsche as fwd ev motor and rwd hybrid?
  7. austingreen
    13,591
    4,132
    Austin, TX, USA
    Doing this makes more sense than trying to mate the prius's hsd from the prime to a flat and awd. Maybe that is what they meant. The brz already has rwd that was probably was designed with a toyota psd in mind, perhaps the unit in the Lexus IS hybrid. The 2L engine may be able to go in unmodified.
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    A plug-in, 25-30 EV miles, upper 30's mpg real world highway, Outback would be awesome. The flat-four design is well known for smoothness so adding a torquey electric motor would be one heck of a sweet combination.
    I always wonder what if Toyota had put the Camry hybrid drivetrain in the Venza.....
    Tideland Prius likes this.
  9. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    That could be the next-gen Prius v.
    fotomoto likes this.
  10. padroo
    padroo Senior Member
    2,763
    2,251
    Maybe they will use a variant of the Prius AWD system but I know nothing about it.
  11. mikefocke
    3,719
    1,662
    Sanford, NC
    But the size of the Venza would just drag the v's MPG down further.
  12. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    I have been saying for about half a decade Subaru needs to utilize their relationship with Toyota to develop hybrids!
    The Crosstrek Hybrid granted a whopping 1mpg increase over the non-hybrid. And it required you to give up the Eyesight package.
  13. royrose
    1,389
    951
    Foot of Pikes Peak
    Let's hope they learned something from that experience.
  14. Tideland Prius
    16,195
    Yeah, I think a HiHy got better mpg or very close mpg to the CrossTrek Hybrid - I used the two to show the advantages of a full hybrid system - a near 2 tonne 7-pass midsize SUV can get the same mpg as a 5-passenger compact crossover.
    RCO likes this.
  15. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    In December, Subaru announced that it would join EV Common Architecture Limited, the company formed earlier in the year by Toyota, Mazda, and parts supplier Denso to provide shared components for electric cars.
    Shortly thereafter, EV Common added small-car maker Suzuki, along with two more Toyota affiliates: the minicar company Daihatsu, and the truck maker Hino.
    But Subaru is adding a few twists, he said, including a longitudinal Subaru engine, rather than the Prius Prime's transversely mounted Toyota powerplant.
    Tachimori said Subaru's plug-in hybrid initially will be sold only in U.S. states that have adopted California's zero-emission vehicle regulations.
    He declined to say what model the plug-in hybrid will be based on. But he said the vehicle will be exported to the U.S. from Japan.
    Subaru plug-in hybrid to use Prius Prime parts, coming in 2019
    http://www.autonews.com/article/20180205/OEM05/180209959/subaru-electric-vehicle-future-product?X-IgnoreUserAgent=1
    kevins007, RCO and Prodigyplace like this.
