Subframe replacement help 2018 Prius prime
Discussion in 'Prime Technical Discussion' started by Johnny be good, Dec 8, 2022.
  1. Johnny be good
    Johnny be good New Member
    2018 Prius Prime
    I need to replace 2018 Prius prime subframe? Anybody has a diagram/procedure on how to do this to replace it with a new subframe. Please help show me what are the steps to get this done. And about how many hours it take to get this done. I took it to a mechanic shop and they’re charging me $1,200 just to replace the subframe umm sounds kinda too much don’t you think.
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    The removal and installation procedures for the front suspension crossmember sub-assembly are in the Repair Manual (more info), under Suspension: Front Suspension: Front Suspension Member.
    The crossmember sub-assembly itself, shown in Figure 51-02, Suspension Crossmember & Under Cover, has part number 51201-47072 (formerly 51201-47071), list price $1,498.88. For its removal and replacement, you’d also need two new nuts for the steering link assembly (94188-01401, sold in the U.S. as 90177-A0017, $1.75), and two new cotter pins for the tie rod end sub-assemblies (95381-03025, $1.35), all shown in Figure 45-05, Front Steering Gear & Link, as non-reusable parts.
    Toyota’s Flat Rate Manual series doesn’t give a labor time for this operation.
  3. Mendel Leisk
    38,726
    Presumably just the labour?
    Borrowing from @Elektroingenieur's link, is it the middle piece?
    I "think" front is at the left?
