subzero tempratures and the warning light
Discussion in 'Generation 1 Prius Discussion' started by juss, Dec 7, 2008.
  1. juss
    juss New Member
    birnamwood, wisconsin
    2003 Prius
    for only the second time since I bought my my 2003 Prius. The little turtle warning light came on. When I bought the Prius they told me to never run the car when the light was on.
    Today is sunday and all the dealerships are closed. I cannot find a troubleshooting phone number. I'm 175 miles from home and i was planning on leaving at 4PM (as soon as I get out of work.) to go home.
    The tempuratures was well below zero last night.
    The last time this happened it was 20 below and the car would not start at 11pm after a movie. and the next morning (still sub zero) the little turtle light came on. We had the car towed to the closest toyota dealership. It sat inside and and was fine that afternoon.
    What do I do now, go home with the light on. stay and have toyota tow it tomorrow. (getting trapped here for another day. I'm expected home tonight)
    has anyone else had this problem
  2. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Turtle warning light? You probably mean triangle of death with exclamation mark warning light?
    If it is the second, check if something stupid is not happening. Like your doors still being open while trying to drive away.
  3. Patrick Wong
    18,200
    6,474
    The turtle light is telling you that the traction battery cannot deliver much power. If you see no other warning lights appear, then this hopefully is a temporary problem due to the cold weather. It is OK to drive the car as long as you don't stress it via full-throttle acceleration.
    You can try driving home, as long as you have a cellphone available to call for towing help in case you get stranded. Suggest you keep your speed moderate as long as the turtle light remains on.
    I had the turtle light come on once when driving my 2001 on steep mountain roads heading to Lake Arrowhead (southern CA). However the car continued to function, I just slowed down until the light went off.
    Good luck.
  4. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    If it just the Turtle warning light (without the triangle light), you can still drive but your prius will have very low power. The turtle light is just a warning for the battery have very low output due to the very low temperature and/or there are not much power left in the battery. Once your car warm up the turtle light will be gone. (I do have it on my 01 once, I left my car park outside for overnight and it was -23C (-35C with windchill factor). The turtle light stay on after I start my prius and it gone after 10 minute of warm up+driving.)
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    The "turtle" indicator light is unique to the Classic (01-03), something we don't have on the Iconic (04-09).
    It just tells you power is limited until warm-up is complete, so don't attempt heavy acceleration. No service is needed.
    During my 3 years of 2001 ownership in Minnesota, I never saw the turtle... even on the horribly cold Christmas when the daytime temp only got up to -13°F.
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    .. i'm surprised you classic owners haven't changed your battery air intake to the inside... (shrug)
    i assume it's impossible to garage the car at any time?
  7. john1701a
    12,755
    5,245
    57
    That's because it is already that way.
    The vent on the outside is in addition to the internal vent near the back window. So, one could block the external one.
  8. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    Relax, the turtle just means the traction battery is cold and the car will be pokey until it warms up. Don't try any split second rushes into freeway traffic until you get used to it. The battery will warm itself by pulling air from the passenger compartment. You don't have to tell it anything, it knows to do this. Which dealer is this that wants you to have Chelonaphobia (the fear of turtles)?
  9. ChapmanF
    15,615
    Also, the one on the outside is a gozouta. The air path is from the intake above the rear seats, ducted to the passenger end of the battery and below it, emerging from the driver end and above.
    -Chap
  10. klodhopper
    klodhopper New Member
    537
    153
    Colorado Mtns.
    2002 Prius
    I've seen it once on ours, when it was @-15F. Once the car was warmed up we shut it off and started it back up again, and it was gone...never to be seen again.
    We also try to make sure that the main battery is as close to full as possible when it's parked in subzero conditions, because sometimes it uses a lot of main battery to start the car. We have just assumed that the car's ECU sensed main battery voltage level was too low after starting at that temperature.
    Haven't seen it since...:cheer2:
  11. juss
    juss New Member
    2003 Prius
    thanks everyone.
    It happened again and I did what you suggested and let it run.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    This could be the only time it is a good idea to allow the car to warm the engine before driving and have the heater on to warm your battery during warm-up.
  13. bturner425
    bturner425 New Member
    Amherst, Ohio
    I got the turtle light this morning for the first time (2001 with 110,000 miles). It is -13 here in Ohio. I drove the car for about 10 minutes to work and the light went out. I had the car parked outside last night instead of in the garage. I will be looking for the light tonight when I leave work. At least now I know what it is.
  14. anarchybro
    anarchybro New Member
    monrovia, cali
    2002 Prius
    my "turtle" light went on today, about 45 minutes after I had been driving it. I will be calling the dealership and asking about this matter. I am assuming I will need a new battery, right?
  15. Patrick Wong
    18,200
    6,474
    That is not a good assumption if you don't have any warning lights on besides the turtle. The turtle light usually means that the battery was overheated, too cold, or deeply discharged, and you need to slow down. This can happen if you are climbing a steep hill. Once the turtle light goes off, you can resume normal driving.
