Sudden Burst of Speed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fullogas12, Jul 16, 2009.
  1. Fullogas12
    Fullogas12 New Member
    Los Angeles
    I've had my new 2010 Prius III for about two weeks. I've had something strange happen twice now.
    While driving in ECO mode, when letting up from the gas I suddenly have a burst of acceleration. The first time it was pretty minor like the car had slipped a bit on the roadway so I didn't think anything of it. Earlier this evening it happened again. This time is was much bigger as if someone had hit the car from behind. It was big enough to slam my head back into the headrest. There was no one around me so I definitely didn't get hit from behind.
    This worries me.
    Has anyone else heard of this happening?
    I'm going to call the dealer in the morning to see what they recommend.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Did the engine seem to be revving at the time? I used to get this quirk in my Gen II (more of an engine rev after let off vs. a burst of speed though).
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Scary:eek:
    I would call immediately and perhaps not drive it at all (Toyota Roadside Assistance). Of course I am pretty cautious.
    Hope it is nothing serious,
    Peter
  4. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    The only thing I can think of is the "surge" from when your wheels slip during regenerative braking. (Rare, but usually experienced under fairly hard braking coming to a stop on uneven pavement.)
    What was happening, in more detail? Did you let off suddenly? Had you been accelerating or a constant speed? Did you let off and immediately start braking? Was the road bumpy? Are you a left-foot braker?
    The alternative seems unlikely, so I'd definitely take the car in for service if I were you, but if there are a couple of other factors involved that you didn't originally think to mention, it might save you time and money.
  5. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    What was your speed before and after the surge?
  6. moner
    moner New Member
    302
    59
    Vancouver, BC
    I sometimes get this surge at a certain point on my commute. It happens going downhill, on a bumpy road, and going about 5km/hr with foot on the brakes slowing to a stop sign. I will feel the car suddenly try to accelerate and I need to push the brakes alot harder to stop the car. I called the dealer and he said it was "normal", something to do with the engine modes transition or regenerative braking? I also noticed a slight speed surge once when I hit some gravel accelerating into traffic. These surges don't feel dangerous yet, more startling, but on a slick road or with pedestrians around it could be scary.
  7. bwilson4web
    15,513
    If you have a Garmin GPS nuvi, there is a data record of your vehicle that we can analyze. It is a large file so transfer may require cutting a CDROM and postal mailing:
    1. mount the Garmin nuvi with the USB cable.
    2. copy GARMIN\GPS\Current.gpx to local system
    3. check the size of file
    4. copy to a CDROM
    5. contact me for mailing address
    If you are able to reproduce this problem, clear the "Track Data" and repeat the experiment.
  8. Fullogas12
    Los Angeles
    I hope I can answer your questions:
    1. I was going about 30 MPH. I'd just crested a hill and had been accelerating steadily. I'd just eased off the gas.
    2. I didn't notice a reving sound. This makes me think it has to do with the electric motor
    3. I definitely felt something like a transmission dropping into gear when the surge hit
    4. Was too surprised to notice if there were any warning lights
    5. I have the navigation package. Is a Garmin built into the package? If so, I can probably access the info. I can pinpoint it to within 5 or 6 minutes. I'd just gassed up a few minutes earlier so I can get pretty accurate on the time
    6. I called the dealer today. They said I could bring it in on Saturday but they hadn't heard of anything like this before
    I'll drive the road again in the morning to see if there was anything weird about the road surface there. I don't recall seeing anything unusual about the road.
  9. sglauberman
    sglauberman New Member
    Ann Arbor, MI
    Well I just got a 2010 Prius and during the first week I have had 3 separate incidents of non-threatening sudden acceleration. In each instance, I hit a bump in the road and the car instantly started to accelerate. Pressing the break immediately slows it down but there is certainly a problem. Today when it happened I noticed that the losing traction warning light came on and stayed on even when the car was at a stop. The light went away when I turned off and on the car. Definitely a problem.
    From reading other posts here I am getting very concerned. I would like this fixed but it is now seeming like the response from dealers/Toyota will be either it's normal or I am crazy. Could be selling my 2-week Prius soon if that is indeed the response I get from the dealer this Tuesday when I bring it in.
    --Steve
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sure sounds like a glitch in the programming. I sure hope the dealer does something about it. Got to the very top person at a minimum. Call Toyota directly if that does not work out.
  11. phvdriv3r
    phvdriv3r Defender of the Glass - Lemon-ed a 2012 PHV
    127
    30
    I have had this happen twice so far... Running a 2010 IV... each time it happened, it was making a right turn and had started to slow down by letting off the gas and starting to apply the brake. The second I felt the surge in the engine, I hit the brake harder because the car started to accelerate as if I had slammed the gas down. No warning lights illuminated.
    I will be advising the dealer of this when I am there next week.
  12. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I do not have a 2010, but this sounds allot like regeneration disable due to a slippery surface. When your foot is off the gas, all the way, like the time when its going from the accellerator pedle to the brake, the car is regen. If you hit oil, or loose gravel at the bottom of a pot hole (common places for pot holes are in the ares just before where stopping occurs - due to heavy loads placed on these areas by trucks and SUVs) one of the front wheels might slip. In which case the Prius disables regeneration and changes to friction brake ABS action. But, if your foot is not on the brake yet, what it feels like is an accelleration, because before the regen disable, you were decellerating. The Prius has a built in no-peddle decelleration setting by HSD regeration. So, you subconciously tense your neck and body against the decelleration, and then all of a sudden the car is not decellerating, and your neck and body react as if they were thrown back, but in actuality it was your own muscle tension that is creating the effect.
    This can even happen when the foot is on the brake, if the brakes are dirty/rusty/wet. Which can happen if they have not been used much. Because the transition to the friction brakes is a transition to brakes with allot less force than the electric brakes in this circumstance.
    Here is how to avoid it. Avoid lifting the accellerator, or pressing on the brakes when your car is running through pot-holes/gravel/shinier spots of asphalt on a rainy day. That is, see a pot-hole while braking - lift for just that instant until you are past the pot-hole.
    There is another actiong going on here. Friction brakes in traditional cars grab between 5 and 0 mph as your braking - creating a jerk to a stop. The Prius is switching to friction brakes at 7 mph, and which typically have less force than the electric brakes. This creates a slight jerk forward rather than backward.
    Additionally, if its been raining, or your car has not been driven for a while, its a good idea on the first shallow downhill to shift into neutral, and brake slowly down that hill. This will force the car to use the friction brakes, and in so doing clean up the surface of the friction brakes. Which will result in less of braking force change during the electric to friction change over.
    6 people like this.
  13. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
  14. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Mine did this over a bumpy area just yesterday, I put it off as wheel hope while braking
  15. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    I've had more power than expected when going from park into reverse..... not the pedal to the floor for sure in this case. :confused:
  16. WaterbedWarrior
    WaterbedWarrior Going insane!
    65
    23
    33
    Parma, OH
    I had a sligthly different experience this morning on my way home. Cruise control was on and set to 60 mph, transferring from one interstate to another, right side exit offramp with fairly sharp left banked curve elevating to merge onto different interstate.
    The offramp was a bit rough and the car started to accelerate midway through the offramp.
    It hit 62mph before starting to slow down. No tire squeal.
    Just felt all wrong as the car was continuing to accelerate past my cruise control set point while going uphill. I often drive this route as it is between my girlfriends house and mine. This is the fastest I've taken this offramp as there is usally traffic slowing me down.
    Will try to reproduce later this week.
    Environmental conditions: ~8AM, 83 degrees F, extremely high humidity (about to start raining) but road was dry.
  17. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    This sounds partially like the known problem of bumps while
    braking confusing the regen system enough that the car gives up
    on regen entirely and falls to physical brakes for the rest of
    the stop. That produces that little "sag" feeling and may
    require foot pressure adjustment, but most second-gen drivers
    are used to that and as mentioned, have come up with clever
    avoidance strategies to avoid it when possible.
    I wouldn't be at all surprised if the same thing exists in the
    third-gen, and I've just posed a related question about what
    one sees in the HSI in my ongoing document about same. It is a
    protective mechanism -- bumps cause wheel speeds to change rapidly
    and thus regeneration current to experience high surges -- the
    Prius system sees those pulses and drastically limits regen
    current to avoid sending too much of that through the inverter
    into the battery.
    However, if the OP is very sure that the event only stemmed
    from backing off the go-pedal with NO involvement of the brake
    pedal and WITHOUT the cruise-control enabled, then that sounds
    like a different and more serious problem.
    _H*
  18. goingreen23
    goingreen23 New Member
    28
    NM
    I'm one of the statistics. I was slowing down at an intersection and was applying the brakes, went over a pothole and the car just accelerated with my foot still on the brakes lightly. Weird and scary though.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I noticed a subtle surge this morning as I was in the parking garage, heading slightly downhill, around 5-10mph and I took a sharp right turn into a parking spot. As I started to turn and let off of the gas, it seem the car was free rolling (no regenerative braking) and to me that felt like a surge as I am use to the regenerative braking slowing me down once I let off the gas. I didn't panic but I sure got on the brake faster.
    I don't know if this has anything to do with what others have experienced but it was new and odd to me and thought I would mention it.
    Peter
  20. ksstathead
    1,244
    243
    Kansas
    What was your speed before and after this acceleration? Any chance you mean that you felt a surge as when regen is cancelled but the car did not actually speed up?
