Sudden & Consistent Drop in MPG
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John in LB, Apr 24, 2008.
  1. John in LB
    John in LB Life is good
    399
    27
    Orange County
    Hi folks, my 2006 Prius has approximately 40,000 miles. I have consistently obtained 44 to 45 MPG on every tankful. About 1,500 miles ago, my gas mileage suddenly dropped to 38 to 39 MPG.
    The obvious things have been checked: Tire pressure, unusual noises or sounds from the engine compartment.... all is normal.
    I did not change anything about the car during this time period.... same tires, same oil, same gasoline...
    Before I go to Toyota and have them go on a fishing expedition... i thought you guys may have some suggestions or things to consider.
    There was a brief time (in the beginning) where it seemed the battery state was too high (green) and the engine was having to run to dump the excess energy... but this seemed to happen for only a 100 miles or so... during this time, I thought maybe I had a bad voltage regulator... which was overcharging my battery... but this was just a hypothesis.
    One more thing: I have a perception that the engine has less power.... seems to be revving higher to achieve my desired acceleration rate then previously - e.g., when trying to get on the freeway. If there is a drop in power, it is slight and not something that is blatantly obvious (like hesitation or stalling out or rough idling).
    Any ideas will be appreciated.
    Thanks.
  2. Patrick Wong
    18,200
    6,472
    I suggest that you raise the rear of the car, release the parking brake, and try spinning the rear wheels to see if they freely spin. If they do not freely spin, then the parking brake is dragging and causing the mpg drop that you noticed.
  3. John in LB
    399
    27
    Orange County
    I will double check that... However, I don't think that's it. Last week, I serviced the car (40,000 mile service) and as part of that work, I rotated AND adjusted my rear brakes. When I am done adjusting the brakes (I usual rotate the clicker 3 to 5 ticks), I always check for free wheel spin. I did not notice anything unusual at that time.
    I just finished a longer freeway drive on a level road. During most of the time the battery charge level was in the green (7 out of 8 bars)... is that normal? I just don't remember - and my impression is the battery is typically in the blue.
    I am also in the middle of checking the accuracy of the MPG indicator (maybe the fuel metering device is bad and overstating the rate of fuel consumption by comparing a manual calculation at my next gas station fill up with the indicator. As the perceived mileage drop is around 15%, versus a metering uncertainty of around 5%, I should be able to tell if the MPG indication is a "lie" or if it is relatively accurate.
    Your suggestion was excellent - and would appreciate any other. In particular, I don't trust the Toyota technician... I would rather go in with a specific problem for him to chase down.... rather than a wild goose chase.... with lots of parts being replaced on a guess.
    A couple of issues that someone can answer for me:
    - When a battery cell goes bad, what does the charge state on the display look like? does it go towards a green? or more towards the red?
    - Can it be a bad voltage regulation problem - resulting in a continuous attempt to overcharge the battery?
    - What issues have been found with the IC engine which could result in a horsepower / MPG drop as i have described? (hmmmm... I did change the air filter at 30,000 miles.... but what if something is blocking the intake... debry... etc... will check on this too)
    Again, any help would be appreciated.
  4. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    It's warmed up here on the East Coast, enough so that the war department insists on turning on the A/C! I swear she doesn't think the windows go up and down!
    It's caused a small drop in the MPG.
    Could you be running the A/C a bit more than normal?
  5. charansr
    charansr Member
    107
    Concord CA
    I would have your spark plugs checked.. Reduction in Power and MPG ? Ummm.....
  6. John in LB
    399
    27
    Orange County
    It's not that - have had the car for 2 summer seasons - and would guess the impact of the AC / temperature is on the order of 1 or 2 MPG... Before this issue I have NEVER had a tankfull of gas average less than 40 MPG.... now, I can't get over 40 MPG (given our driving style).
    Thanks anyway.
  7. John in LB
    399
    27
    Orange County
    Spark plugs at 40,000 Miles? I guess I could check them - to just to eliminate the issue.... however, I am doubtful - besides, its not running rough or ever missing....
    Thanks for the suggestion.
  8. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    bad gas? water in the tank? You said it came on all at once. junk in the line or injectors?
  9. Patrick Wong
    18,200
    6,472
    Hi John,
    When the traction battery fails, you will see the SOC indicator move up and down much more quickly as compared to when the battery is functioning. This is due to increased internal resistance which causes the measured battery voltage to fluctuate up and down more than normal.
    If your SOC gauge is staying in the low green to high blue area, then this seems pretty normal.
    It wouldn't hurt to check the spark igniters and spark plugs just to make sure that there are no problems (for example, moisture in the spark plug tubes that cause misfiring.)
    I assume that you have no warning lights on, so if any engine problem exists, it must be subtle.
    What gasoline brand and octane level are you using? Should be using 87 octane regular, ideally a top-tier brand such as Chevron, Shell, Union 76 etc.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Did you bump a curb? Check the wheel alignment. Other suggestions have been covered by others.
    Oh by the way there is no fuel flow measuring device. Fuel consumption calculations are made from injector dwell time, multiplied by frequency or RPM then multiplied by a known injector flow rate divided by speed over the road.
  11. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    Is there any chance that your gasoline now has ethanol added????
  12. John in LB
    399
    27
    Orange County
    Thanks for the battery info. I don't think my battery SOC level is fluctuating in unusual manner - just staying higher than I am used to.
    This car runs 100.000000% Chevron gasoline - 87 Octane. :third:
    I guess I should check the spark plugs.... but we are talking real subtle..... if there is a problem.
    Thanks.
  13. John in LB
    399
    27
    Orange County
    Thanks for the input about the fuel metering. I definitely do not have a wheel alignment issue (not that I just put it on a machine - but I just know, based on car feel, no damage to wheels, no unusual wear pattern on tires.)
  14. Bob64
    1,540
    92
    Virginia
    Check your engine air filter? Perhaps something wrong with your oil filter?
  15. John in LB
    399
    27
    Orange County
    It's not the oil filter - I changed it and oil after the MPG drop (at 40,000 mile service)... and it did not make any difference.
    I am definitely checking the air filter and the air intake passage when I get home (out of town for a few days).
    Thanks... air filter/intake blockage and sparkplugs are the two things on my list...
  16. Bob64
    1,540
    92
    Virginia
    I'd also try another gas station. Shell for example. Perhaps that station has had a different set of cost-cutting additives added or has switched suppliers?
  17. John in LB
    399
    27
    Orange County
    We checked all of your suggestions and went to the toyota dealer - the car still gets 39 MPG....
    We checked air filter and air passage for any blockage
    We checked the computer codes for any errors
    We inspected sparkplugs
    We checked tire pressures
    We adjusted the rear brakes a little (they were dragging slightly)
    The dealer cleaned the carburator throat for carbon deposits buildup (the old gumout treatment)...
    Something happened to this car about 6 weeks ago, resulting in a sudden and permanent drop in gas mileage (from ~ 44 MPG to 38/39 MPG)....
    At this point - WE COULD USE SOME HELP... or suggestions...
    Thanks in advance.
  18. bwilson4web
    15,518
    We need to know what is happening when your vehicle is getting 39 MPG but we don't have any detailed data. We need to take an empirical approach to find out what is going on and that means running instrumented tests. This may require some technical skills and instrumentation that you'll have to setup and run.
    My first question is to find out what your vehicle performance is above and below 42 mph, the boundary between two control laws. What I would like to propose is to look around Orange County for a test route you can drive without stopping, or a minimum number, in light traffic conditions:
    • 45-60 mph cruise control speed - some place were you can drive for ~20 minutes at ONE constant, cruise control speed on a level road. Check your local freeways to find a loop that you can safely drive at this given speed. Do one practice loop and then reset the MFD display and listen to the radio or tunes for 20-30 minutes. When you get back to the starting point after 20-30 minutes, report the MPG and miles and speed (or start/stop times.) Temperature is also needed.
    • 25-35 mph cruise control speed - a route where you can drive for ~20 minutes at one constant, cruise control speed on a level road. Check your local streets but large shopping center parking lots are prime candidates. Repeat the same test at one speed for 20 minutes and record the MPG and miles and speed (or start/stop times.) Temperature is also needed.
    Since these areas are away from your home and work, report their location so we can look at the route using Google Earth. This will let us understand how much altitude change was involved. We will take your numbers and compare them with this chart to see if we can see a pattern that indicates where the problem might lie:
    This will let us isolate auto-stop operation apart from ICE powered operation. It will also put the ICE in two power ranges to help fault-isolate the problem(s).
    Do you have a laptop with a stereo microphone input? This would allow using audio capture software to measure some vehicle sounds during operation. In some cases, we can actually record some energy flows that are ordinarily invisible. What operating system does it use?
    Do you have or would you consider getting an OBD scanner that runs from a laptop? This would allow us to look at some of the metrics that can be captured from the bus. The problem is this is an advanced area and we'll have to ask some of the folks at the leading edge to help with the data analysis. The capture is simple, just record everything from the OBD. The analysis will be the problem.
    I do not remember seeing your existing 39 MPG route being posted with start and stop addresses and route. Using Google Earth, we can look at alternate routes that might for the expense of a little more time, give some immediate mileage relief. If you are concerned about privacy, give starting and ending locations offset a block or so from the real addresses. Just try to make sure the 'mock' addresses are at the same altitude.
    There are a few problems that are very difficult to diagnose. Folks have already shared what we call "low hanging fruit" and it looks like you've make a good effort. But the hard problems often take a bit longer to figure out.
    One thing not clear is how you measure your MPG. Is this on a daily basis or just per tank? It would be useful to reset the MPG display in the morning and start tracking the MPG and distance at the end of each day. In my case, I monitor each trip by resetting the MPG each time I start and check it when I will be parking for more than an hour. This allows me to see patterns that have and continues to teach lessons about how our Prius runs.
  19. Patrick Wong
    18,200
    6,472
    1. Did the mpg improve at all after the rear brakes were adjusted?
    2. Did the mechanic check the engine coolant temp? It should be around 85 degrees C. I am wondering whether your engine thermostat might be stuck open, which would cause the engine to run inefficiently.
    3. What tire pressure are you using?
    4. Although you had previously dismissed this as an issue, I suggest that you have your wheel alignment checked. Front toe-in should be as close to zero as possible. Rear toe-in is normally not adjustable by the dealer, but see how close to spec it is.
  20. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    I've noticed exactly the same problem with my 2006 for the past month or more, and I'm willing to bet money it has something to do with all the gas pumps having a "10% Ethanol Added" sticker on them here in South Florida. Does anyone know a station NOT adding ethanol? :mad:
