Sudden Coolant loss
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Heatherm, Nov 29, 2024.
  1. Heatherm
    Heatherm New Member
    Ky
    I’ve been reading and learning here. Finally decided to post. Have a 2012 Prius and no trouble until a couple days ago. Was driving and high temp light flashed on. When I got home the coolant was really low. I used a camera scope to look inside but didn’t see anything “steam cleaned”. Also bought HG compression kit test and the test was negative for gases. Have ordered water pump and thermostat. The only code scanning is B1503. Should I go ahead with water pump or is this likely the head gasket? Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    12,003
    2,123
    Durham NC
    You can call up water pump operation w good scan tool . And wen ya do you can hear pump sounding like it's running but a trained ear will hear other things like the 800 rpm it's saying it's spinning is actually half that or similar antics going on . It's a real thing . No water pump will solve leaking HG. But a slow spinner can certainly bring temps up . Usually peeling impeller try the 35 dollar solution first. That could help save ya thousands. Operative word being could... Good luck
    Heatherm likes this.
  3. Mendel Leisk
    40,459
    What’s the miles?
    Brian1954 likes this.
  4. Brian1954
    Brian1954 Senior Member
    1,703
    664
    South Central PA, USA
    What water pump and thermostat did you buy? OEM or aftermarket?
    I would replace the water pump to see if that fixes the overheating. While you wait for the water pump to arrive, I would monitor the engine coolant temperature by using an ODB2 Bluetooth dongle and an app.
  5. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    What is a HG compression kit test? Are you saying you did a compression test on all 4 cyclinders or did you just put in some chemical indicator in the coolant and that's negative?
    In the meantime. refill the coolant level and burp the system. After all the bubbles are out, mark coolant level, then monitor.
    Hope this helps.
  6. Mendel Leisk
    40,459
    I'm guessing he bought the gizmo that checks for exhaust gas in coolant, which is not what usually happens with gen 3 head gasket failure, at least not in the early stage.
    BiomedO1 likes this.
  7. Heatherm
    Heatherm New Member
    Ky
    Yes, i meant that one. Is there a better diagnostic for hg we could try?
    #7 Heatherm, Nov 30, 2024
  8. Xterra72
    Xterra72 Senior Member
    1,427
    1,669
    This is exactly what happened to me. Second time it happened, read the code and it was the water pump failing. Replaced the thermostat for good measures. Problem solved. Think you are on the right track. Hope it all works out.
    Heatherm and Brian1954 like this.
  9. Heatherm
    Heatherm New Member
    Ky
    Showing my ignorance here but where would the coolant have gone if not into a cylinder? I’m hoping it’s somehow going to be the water pump but I can’t work it out in my mind.
  10. BiomedO1
    2,725
    1,455
    SacTown, Ca
    Yes, that's neither a compression test or head gasket leak test. It simply tells you if exhaust gases is leaking into your coolant. IT DOESN'T TELL YOU WHERE THE LEAK IS. Making an assumption leap like that can cost you serious money and wasted time. IMHO
    Mendel Leisk and Heatherm like this.
  11. Heatherm
    Heatherm New Member
    Ky
    We changed out the water pump and thermostat. The water pump was hard to turn and the thermostat was stuck open I think. Hubby drive it 120 miles today and so far, no coolant loss. Still hoping it didn’t damage the head gasket. Thanks everyone!
    BiomedO1 and Brian1954 like this.
  12. Brian1954
    1,703
    664
    That is a very good question.
    When the engine water pump goes bad on this engine (not enough coolant flow through the engine), the engine overheats, and pressure builds up in the coolant system. When that occurs, the cap on top of the reservoir releases the pressure just like it is designed to do, and coolant is pushed out the overflow.
    Take a look at the two pictures below.
    Take a look at your car for evidence of dried pink coolant around the reservoir.
    #12 Brian1954, Dec 3, 2024
  13. Brian1954
    1,703
    664
    What water pump and thermostat did you buy? OEM or aftermarket? I hope you got OEM. If not, you may be replacing it again in about one year.
  14. BiomedO1
    2,725
    1,455
    SacTown, Ca
    Hose-off and clean that coolant bottle area when everything is cold. That way you'll be able to tell if the coolant is still boiling out, without the temperature light flashing at you. I'm assuming your not going to actively monitor the ECT.
    hope this helps....
  15. Heatherm
    Heatherm New Member
    Ky
    Thanks, we haven’t seen any dried on the reservoir. We drew a line on the tank so we could watch. He’s driven it the last 2 days to work and no loss yet. Still hoping we fixed the water pump and thermostat before it got too hot.
  16. Heatherm
    Heatherm New Member
    Ky
    Thanks, waiting on temp gauge to come in so we can keep an eye on it.
  17. Heatherm
    Heatherm New Member
    Ky
    OEM was gonna take a week and we needed to fix it on the weekend (had to get to work) so we watched some videos that showed a guy taking apart aftermarket ones versus Aisin and he showed aftermarket ones were missing the thermo paste which he said was necessary and that’s why he wanted people to buy Aisin. But since we couldn’t wait a week for that brand we bought a Duralast from Autozone and took it apart. It had the thermo paste so hoping it will work!
  18. Brian1954
    1,703
    664
    Did you buy the car new or used? I am asking to determine if the water pump you took off was the original OEM pump or was it an aftermarket pump? You can tell the OEM pump by "TOYOTA" and "AISIN" cast into the pump. See picture below.
    If the old pump was OEM and you still have it, I would try to remove the rotor from the shaft and then buy a replacement rotor on Amazon ($22) or eBay. Then you will have a replacement pump for the next time you need it.
    #18 Brian1954, Dec 4, 2024
  19. Heatherm
    Heatherm New Member
    Ky
    It was original, that’s a good idea, thank you!
  20. rjparker
    rjparker Tu Humilde Sirviente
    9,498
    5,813
    Texas Hill Country
    By the way there are two temperature sensors on this car, one sensing the coolant temp after the exhaust heat recirculation system (which caused the B1503 at 248f - normal high about 205f). AND the second coolant temp sensor on the head just below the largest coolant hose on the drivers side.
    Clearly the engine hit 248f or higher. As indicated above, you hope the reservoir on the passenger side relieved pressure and dumped coolant. Otherwise it is head gasket or a rare leak in the exhaust heat recirculation system.
