Sudden drop in mileage
Discussion in 'Gen 2 Prius Fuel Economy' started by Fiberbabe, Jan 12, 2006.
  1. Fiberbabe
    Fiberbabe New Member
    Portland, Oregon
    I've got an '02 Prius, with which I've consistently averaged about 45 mpg. All of a sudden, my mileage has dropped to around 30! Within the last 6 weeks or so, I had an alignment, two new tires on the front, and my air filter replaced... and I've been *religious* in my observance of regular maintenance. My car is stored outside, but it's only been in the 30s/40s.
    I'm a little frustrated ~ I've come to rely on the mileage, and now all of a sudden it's reduced by a third, and I don't think I'm doing anything differently! :blink: Anyone have any ideas?
  2. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    Check the obvious..tire pressure. I noticed my '05 drop 10mpg and found ONE tire at 22lbs. I had a slow leak that needed repaired. I am a "tire nut" and it was still difficult to notice it that low by sight (it was rear tire)
    Imagine what a change of 5 lbs in all 4 tires would do?
  3. chuxter_1
    chuxter_1 New Member
    That's what my MPG is currently at. The weather in NYC has been rather mild (40-60 degrees), even though it's January. I haven't had a great MPG avg. since the first month that I owned the vehicle (August). It was in the high 40's- low 50's, but now stays around 30MPG or less!!! I haven't had any work done to the car except for a fixed flat.
    Another funny/bizarre thing was that while I was getting pretty good MPG readings during the first month of ownership, I eventually found out that the dealership actually had my tire pressure all messed up. Tire PSI was much, much lower than what is recommended in the manual, and it was set backwards.
  4. Tideland Prius
    16,609
    new tyres. Let them wear out a bit.
