Sudden Drop in MPG
Discussion in 'Gen 2 Prius Main Forum' started by calpal, Dec 23, 2008.
  1. calpal
    calpal New Member
    52
    Went to get an oil change, air filter, PCV valve, adjust rear brakes.
    Immediately my MPG dropped from an average of 47 to 42. How could this happen? Maybe they put in a wrong air filter, or a bad one, or what? Maybe too thick oil?
    Would welcome your opinions.
    I have an appointment w the dealer in two days to check it out.
  2. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    They may have overfilled your oil. Check your levels.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Check your tire pressure... 9:1 they're lower than you usually run them.
    Also, how did you determine the drop in MPG? It may be a temporary thing.
  4. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    I'd agree, check the oil level but, most likely, they reduced the pressure in your tires. My dealership does that to me every time, I keep it at 44/42 and invariably after a servicing they are at 35/35.
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Was this dealer service that did the oil change, or somewhere else?
    If the counter has not been reset, then you will have an indicated mileage hit from the engine being operated without being driven (during service.)
    Check oil level--Toyota's official procedure calls for too much oil. They might also have used higher viscosity oil.
    Tire pressure is of course the most likely culprit if it isn't just a result of fuel burned idling while being serviced.
    One other thing, check your A/C settings. The tech might have changed blower or temp settings on you for his/her own comfort. If the defrost is running and/or the blower is blasting then your ICE will run more frequently and that will cost you mileage.
  6. Struv1
    Struv1 New Member
    Upland, Ca
    I've had the same problem before, they over tightened the rear brakes. They would barely spin on there own, Dealer loosened them a bit and mileage went back up.
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    This has nothing to do with a service, but
    I was getting over 50 mpg avg. until last week. Was 55ish, went closer to 52 with more short trips, then ...
    refilled with gas, we had some overnight freezing temps and a few storms ...
    the car has settled into about 46 mpg now. Some long trips, medium and short.
    Cold temps, winter blend fuel (?), shorter trips, running defogger more, all takes its toll.
  8. tedmarshall
    tedmarshall New Member
    25
    San Jose, CA
    What state are you in? In California, we just switched to "winter blend" gasoline which reduces pollution but gives worse mileage (typically 10-20%:frusty:).
  9. hobba
    hobba New Member
    85
    Estero, FL
    I've had the same thing happen to me. You might wish to read the thread I started entitled, "After Service Issue" which outlines the cause and solution of the problem for me.
  10. Tdoff1
    Tdoff1 New Member
    122
    VA
    I see a drop when it gets cold.....weather changes
