Sudden engine noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SteveTaylor, Jun 19, 2017.
  1. SteveTaylor
    SteveTaylor Junior Member
    Basingstoke
    Hello,
    I had a full service done on my Prius last week. It has done just over 175k miles and a few days ago the engine started making a growling noise. It is mainly when I am accelerating (but not in battery only mode), it contains to growl if I put it in B to slow down.
    I have had the bearing changed in not front tyres recently and I had the hybrid battery replaced last year when it died a death.
    Has anyone come across this sort of thing before? I was guessing an exhaust issue but I am hardly an expert on cars!!!
    49,433
    that's not a bad guess. how is the oil level?
    valde3 likes this.
  3. SteveTaylor
    Basingstoke
    Oil level is good ... which sucks because that would be a cheap and easy thing to fix :-(
    49,433
    how is the 12v health?
  5. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    I'm guessing you've tried to reproduce it by revving the engine while in park? It only happens under load?
    Mechanic's stethoscopes are inexpensive, or you can use a length of heater hose, to check exhaust joints.
    Have you looked at the transaxle oil? Are the CV boots intact?
    SFO likes this.
