Sudden malfunction on the drive
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mohd. Rashedul Haque, Mar 18, 2018.
  1. Mohd. Rashedul Haque
    Mohd. Rashedul Haque Junior Member
    Bangladesh
    2012 Aqua
    I bought a used Prius C 2012. On the drive, suddenly something happend on my car and I saw four indication-break system warning yellow light, malfunction indicator yellow light, slip indicator light and Car problem indicator (Car icon with '!' sign). Can anyone please help
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    You are most likely going to need to find a way to read the trouble codes to get additional help. Those lights won't come on unless the ECU sees a problem, but with out addition information it could be a whole lot of things.
    49,391
    how many km on her?
  4. Mohd. Rashedul Haque
    Bangladesh
    2012 Aqua
    Thank you for your reply. That's my fear, ECU has identified a problem. Today morning, I have restarted again the car. Now it shows only two indicators - Yellow malfunction, and car hybrid battery (Car with "!" mark). What the things altogether means?
  5. Mohd. Rashedul Haque
    Bangladesh
    2012 Aqua
    97k.
  6. Mohd. Rashedul Haque
    Bangladesh
    2012 Aqua
    I like to give one update about my Prius C. I have contacted local service center of Toyota. They just reset ECU and it is working fine. Today all is working perfectly well. I got 20km/lt.
    Raytheeagle likes this.
  7. Mohd. Rashedul Haque
    Bangladesh
    2012 Aqua
    As I wrote,Toyota service center has reset ECU and at that moment it was operating perfectly. But unfortunately, Got same problem after one day. This time I disconnected 12v battery and reconnect again. Problem solved, I thought. But getting same problem again. Shows two icon - Malfunction, car traction battery problem. I bought this old car from a dealer.
  8. bisco
    49,391
    did they read the trouble codes?
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    As you now see, clearing the codes doesn't fix the problem. The next time the lights come (and they will) get them read and post them here so we can offer some informed opinions.
  10. Mohd. Rashedul Haque
    Bangladesh
    2012 Aqua
    The light is yellow indicators - Cars battery problem (Car with"!") and Malfunction problem. In the previous record of Toyota service center, it was recommended to change Battery Voltage Sensor which my previous car owner did not. Is that High voltage main battery sensor?
