Sudden Mileage Drop Mid-Drive & Other Concerns
Discussion in 'Gen 3 Prius Technical Discussion' started by Selzier, Oct 8, 2012.
  1. Selzier
    Selzier Whee!
    148
    51
    Hi Everyone!
    There were a couple of issues I'm experiencing with my 2012 Prius Liftback that I wondered if other people have noticed. I did a search for these but didn't come up with anything or could not find a solution! Basically I want to know what others have to say before taking it into the shop (I like to avoid shops unless absolutely necessary, and I wanted to knock out everything I've been experiencing in one huge post.) Hopefully you all don't go tl;dr on me!
    First issue I've experienced is that sometimes, randomly, in the middle of my drive, my Prius will feel like it gets a little juice even though there is no change in pedal pressure, geography, or change in speed either. My mileage indicator will instantly drop roughly 10-15 mpg and will last for roughly 20-30 seconds before I feel the "juice" wear off and my mileage go back to normal. I would say this happens roughly once every 15-20 minutes in consistent driving (most noticeable on the freeway). I kept an eye on my ICE indicator and notice no change in my power flows. Anyone else notice this? Do they know what it's for? I was thinking that the engine was switching from using the electric motor to help power the wheels to actually recharging some of the battery power I was using but the ICE indicator still stays all arrows to wheels (like I said typically freeway driving).
    The second issue I've been experiencing is a rattling sound I notice at low speeds (under 20 mph) on paved roads (condition of road doesn't seem to matter). It seems to be coming from my glove compartment (my girlfriend has confirmed this). Emptying my glove compartment has not helped.
    The final thing I've noticed is extremely poor sound quality in the radio/satellite/blue tooth phone calls. I've done a couple of searches on this topic and came up with topics of people discussing these... but to no real fix. Anyway radio reception seems particularly terrible. Also the constant switching from HD radio over to standard radio is very distracting (and I've turned off HD radio completely as I find it more distracting to keep switching from HD to standard 10-15 times a minute). Satellite radio sounds very "tinny" as well with a very metallic echo. This goes as well for bluetooth phone calls, all sounding very very "tinny." People have also complained that talking to me while I'm on the phone there is a terrible echo on their end.
    Other than these "issues" (which may just be perfectly normal things for the 2012 Liftback) I am absolutely LOVING this car. I'm getting an average of 53-54 mpg even with lots of hilly driving and a lot of freeway driving.
    Thanks in advance for your help! Happy MPG's!
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    On your first issue. I assume this happens somewhere during the first 15min of starting the car? I notice the same thing happens but I see that it only happens as the engine reaches 181F-190F. I think it is part of the warm up sequence. Because my commute is so routine I see this happen every day in the same place and at the same engine temp. I started keeping an eye on engine temp after startup and low and behold it happens every time the engine gets to at least 181F+-. So it's normal. :)
  3. MandyTee
    MandyTee 2012 Prius Three ~ Classic Silver Metallic
    49
    16
    Greater ChicagoLand, IL
    I have the same complaint on my 2012 when it comes to the poor sound quality (sometimes). Pandora through Entune sounds like crap, but sounds better via Bluetooth. I've adjusted the sound settings, dropped the treble, bumped up the bass, all in an effort to get it to sound better. My big issue is with my Satellite & HD Radio - they both constantly cut out, to the point that it makes listening to either unbearable. HD radio keeps dropping the signal. I think something might be wrong with my antenna? I'm waiting for the 5k service and adding that to the list of "things for Toyota to fix."
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Did you perform all of the Entune updates? Mine used to sound absolutely terrible (Pandora) but got better such that now I don't notice a big difference between Entune and Bluetooth streamed Pandora.
  5. MandyTee
    49
    16
    I just got the car 2 months ago; I kinda assumed it would come with the most recent update? Maybe that was incorrect on my part, I'll be sure to ask the dealership when it goes in. I'll have to figure out what version I currently have so I can tell if they've actually updated it. Does that update also update the maps? The map is outdated; it does not recognize new roads added my area that were built in the last couple years.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I try to never assume anything when it comes to dealerships unless it is to assume that something hasn't been done. :) Just make sure that you enable "high quality" for the Entune Pandora app.
    I don't think the updates changed the maps but I could be wrong.
    MandyTee likes this.
  7. Selzier
    Selzier Whee!
    148
    51
    Thanks for the replies everyone.
    I did update entune all the way (it just seems like the sound is poor radio reception, although other posts seem to indicate that this is a common problem with the Prius and not antennae related.
    As for the car's mileage moving around every once in a while, I notice it even after driving on the freeway for over 20-30 minutes which should be well over the car's warming up cycles. Anyone else seeing this? On flat terrain suddenly the car seems to gain roughly 5-6 hp at the cost of 10 mpg which lasts for again roughly 10-15 seconds.
