Sudden mpg drop after service check
Discussion in 'Gen 2 Prius Fuel Economy' started by Chronos, Dec 2, 2010.
  1. Chronos
    Chronos New Member
    Austin, Texas
    New to this forum. Having MPG issues. Dealership not helpful. Regarding the questionnaire :
    2007 Prius, owned since new, prior 3 years fuel economy was 48/54 city/hwy no AC & 45/50 with AC. Live in Texas ‘hill country’ summer starts in late May with 90 degrees & 25% humidity goes through mid October. Highs in August over 100 & 25% humidity. Some small gentle hills i.e., not pancake flat like the rest of the state. Determined MPGs both by computer & dividing miles driven by fuel added. Was happy with this. Driving habits have not changed since owned car, 15 miles each way to work 5 days a week, in 30-45 mph light stop & go traffic, couple times a week in town hwy driving at 55-65 for 5-10 miles. About 70% city 30% hwy. Occasional long hwy trips at 70+ mph gets the 54 mpgs. Never checked oil level, leave that for techs, all equipment is original, don’t know how to read the 12v battery. No alignment issues or unusual tire wear. Tire pressure same as factory settings 35psi. Use to own a ’98 Ford Mustang. 15/20 mpg in same conditions. Driving habits are typical, not trying to stay in electric mode, average braking, rarely use the B mode, nearly all D mode. Have never warmed up engine before driving. Rarely need heater in Texas, use AC from May through October but being cold naturded don’t usually like it on high blower or lowest temp. More in the middle, 72 degrees and low blower.
    Here’s what happened. Took car in for 30k check up. Immediately after that – same tank, noticed significant drop in mpgs, down to 40 in city or less. In addition, computer readings were no longer consistent as they had been in past. Sometimes it would say I got 48 mpg when my calculations were 40, sometimes it would say I got 40 mpgs when my calculations were 43. No longer gave accurate readings for outside air temps. And previous 3 years when add fuel warning came on it would take 10-11 gallons gas, now takes 8-9 at same point.
    Talked to dealership, they blew me off, tried to tell me the government had recently put new additives in gas that was causing this 20% decrease in my fuel economy but no one else's! Made detailed records for 10 tanks in a row, all the info shown above. Wrote complaint to dealership, they finally looked at it & said it was a dirty master airflow sensor. Cleaned it for free. Still got 40 mpgs. Until stopped using the AC in October. Then it went up slightly but not back to previous experience. Dealer has it now, going on 2 weeks. Keep bouncing me around from one agent to another, none of them keep track of what I have told them & all are blowing me off.
    [FONT=&quot]Since the tire pressure & oil have always been handled by the dealer & supposedly not changed in 3 years, all the equipment is original, dealer diagnostics say it is all fine/within normal parameters & one of the issues this forum has recommended (master air flow sensor) has been addressed my question is : How can I be sure it is that 12v battery before I change it? I would really like to prove to the dealership that I am not nuts & they are missing a significant issue.
    Thanks for taking the time to read 7 respond to this really long post.
    [/FONT]
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    please check them yourself
    First off, you've posted in the the wrong area. You have a Gen II. I've flagged it for the mods to move it to the right area. Anyhow, welcome. :welcome:
    You need to go and check the oil and tire pressure yourself. Having it "handled by the dealer" doesn't tell us anything. I've and others on PC have had personal experience w/dealers overfilling oil while doing oil changes. I've had dealers more than once muck w/my air pressure when I told them not to. In the most recent case, when they lowered my pressures to 35 F/33 R, I told them to bump them back up to 40 F/38 R. Service advisor replied, ok, we'll get someone to do it. I get home. Guess what? There were still at 35/33. :(
    Regarding checking the 12 volt battery, there's a link to the method in http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html.
    As for manual calculations not necessarily matching that of the MFD and the going back and forth w/the readings. That's totally normally. I've seen that since day 1. You need to average out both, over time.
    Don't use B mode at all.
    From 10 Day Weather Forecast for Austin, TX - weather.com, your temps have dropped but I doubt they'd be enough to cause a 20% drop.
  3. thbjr
    thbjr Member
    326
    62
    Phoenix
    Welcome to PC. Sounds like there was a screw up at the dealership. When one can show litterly years of MPG tracking and that suddenly changes and the change happens in the middle of a tank full but coinsides with a trip to the dealer, well, is it JUST coincidental? I think not!!!
    I don't know if you'll ever know the truth, but an educated guess from the evidence would suggest something fishy happened at the dealership while in for service.
  4. magic-man
    magic-man New Member
    31
    Trinidad
    It sounds to me like they cleared the computer.... It will take about 3-6 weeks for the computer to re-learn your driving habits and adjust accordingly... If they tested your 12V battery, this could have done it. Some dealers disconnect it to do the load test to protect the electronic systems.
    Each time they cleared it on me, I got crappy MPGs for a few weeks until the system re-learned the hyper-mile strategy.
  5. macmaster05
    macmaster05 Senor Member
    4,050
    727
    whoa whoa whoa, the government has recently been putting additives in gas that lowers mileage for prius/hybrids??? Is this true?
  6. don_chuwish
    don_chuwish Well Seasoned Member
    816
    180
    Southern Oregon
    I'd like to know more about this. I've read the theory floated several times but haven't seen much detail. Is it really so smart as to "learn" how I drive or is it more about the computers adjusting to how the car is performing?
    - D
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    Check your oil, 2/3rd's up the dipstick is preferred, not at the top, cycle your emergency brake on and off a few times, they may have adjusted the shoes tighter, manually. Change out your 12 volt battery for an Optima yellow top and it's fit kit. Pump your tires up to 42 front 40 rear, check your engine and cabin air filters, clean the cabin filter in the sink with soap and water, replace the engine one or if it's a K&N clean and oil it.
    Assume they unhooked your battery and wait two tankfuls before the mileage is a concern.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Yes, Every fall, and then every spring they put it back.
    The Oil Drum | Refining 101: Winter Gasoline
  10. gingeratl
    gingeratl New Member
    atlanta
    I, too, have experienced almost identical sudden fuel mileage drop symptoms as you describe. It was following my 30K service in July, 2010 (2008 model) and I also had the recall gas petal replacement done at that time. Immediately following the service, my mileage dropped from 45-47mpg to 38mpg tops. My original tires were worn so we replaced them, and still no improvement. I've had the same issues with fuel fill up as you describe - the low fuel indicator light comes on and the fuel input clicks off at 8.9-9.0 gallons when previously it was higher. I don't have any problem with the outside air temp reading, but the computer calculating the mileage seems to fluctuate erratically though it matches my manual calculations of 38mpg. No luck with the dealer, same as responses you describe.
    Have you had any further luck resolving this matter?
  11. richard schumacher
    7,663
    1,038
    United States
    What else changed around that time? 40 mile commute became 2 miles? 300 pound guy joined your car pool? ran over a tree trunk? started using "B" instead of "D"? It's amazing sometimes what people can forget, or forget to mention.
    Otherwise, check the tire pressures (42/40 PSI front/rear will help a lot), make sure that the oil isn't overfilled, and that the parking brake isn't hung up. Get a diagnosis from another dealer.
  12. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Cold weather and new tires can account for all of this.
    What type of tires did you get? (exact size model brand please)
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Not enough info. Please answer http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html.
    Even if you replaced your tires w/identical make and model, expect to see some drop, at first. See Tire Tech Information - Tire Rolling Resistance Part 3: Changes to Expect When Switching from Worn-Out to New Tires.
  14. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    Yep, I went to SAMS and had the rear tires replaced on my Honda hybrid and my milegae went up. So stupid me thought, " do the fronts and get even better MPG". Stuck on 38 MPG/ARGH!. Tires, thick oil, tire pressure, and what else did they do to your car. Somtimes the traction battery not properly charging and kicking in when it should will drop your MPG. Love my Prius BTW. I always get better MPG than with my Honda.
    Odd, but I have noticed in the last 30 days that my tank won't fill up all the way unless I slow fill it. I wonder if they adjusted the pump pressure shutoffs.
  15. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I wonder how many of these threads are based on owners having their lifetime mpg trip meters reset. Unless you reset the meter yourself on a regular basis how do you know your mpg has really dropped? My 2005 resets everytime I filling the tank but the 2006+ models do not automatically reset. Is that correct?
  16. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Sounds right, I have to reset my 2007 manually.
  17. Rest
    Rest Active Member
    1,210
    53
    CA
    Why would anyone allow a "Stealership" to handle their oil and tire pressure? Their numbers are not for your benefit.
  18. jbkcurls
    jbkcurls Junior Member
    Raleigh, NC
    My 2008 Prius has done the same thing. Mileage always around 50 mpg. 41,000 miles. Since 40,000 mile oil change and tire rotation mileage has dropped to 38. No change in driver/driving. New tires were bought at 35,000 and mileage the same as before with those.
  19. richard schumacher
    7,663
    1,038
    United States
    Check the easy likely stuff first: the oil level and tire pressures.
