Sudden whirring sound from rear and accelerator delay
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Toyonka, Jul 26, 2016.
  1. Toyonka
    Toyonka Junior Member
    75
    I have a strange issue that just started happening. A whirring sound comes from the vent in the back seat I believe which sounds like escaping Air. Not like the last 2 years I've owned it. At the same time I noticed that the accelerator now takes a second to engage after I hit the pedal from a stop every time. Furthermore the engine seems to be over revving, as if engine braking. I've restarted the car a few times. I've checked all the fluid levels. Any ideas?
    Toyota Prius Five Advanced 2014
    (P.S. Tapatalk integration is currently borken.)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    How many miles on her? Have you cleaned the HV fan?
  3. Toyonka
    75
    40k. Hadn't cleaned it.
    The problem did not recur today.
    Cheers!
    49,488
    the fan probably sped up to cool your battery.
  5. Toyonka
    75
    Just weird after 2 years never happening. Thanks.
    Cheers!
  6. bisco
    49,488
    it happens. was it hot out? sometimes it's just because you are in a quiet area not muffling the sound. do you carry pets regularly?
  7. Toyonka
    75
    It's LA so always hot. But we're pretty near the recent brush fire.
    No pets.
    It wasn't a quiet area issue. As mentioned the acceleration suddenly changed simultaneously.
    Not to worry.
    Cheers!
  8. bisco
    49,488
    all the best!(y)
    Toyonka likes this.
