Suggestion for automatic cell charger/discharger
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LKasdorf, Jan 19, 2020.
  1. LKasdorf
    LKasdorf Junior Member
    67
    Waterford, VA USA
    I want to get set up for checking and balancing the cells in my Prius batteries.
    I am a long time electronic tech, and have dozens of meters and electronic stuff. Yes, I can rig up a load, and manually load each cell, and record discharge time to a certain voltage, etc. But I see a lot of smart chargers that do this automatically and don't cost much. The question is, which one to get? I prefer to avoid the inaccuracies of doing it al manually, when I can buy a decent unit for $30-$60.
    I don't plan to get into the business of being a hybrid battery tech, but I do own 3 Priuses and I want to be able to check and recondition my batteries when the situation arises. And I do have an immediate need to isolate and replace a bad module.
    I see a lot of people seem to use the Hobbyking quattro, but I think I'd do fine with a single charger unit. There are many options. I see Tenergy, Eyesky, Venom, etc.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Would you want to do the whole pack at once, and since you have 3 Prii, have you thought about the Prolong equipment sold by Hybrid Automotive:whistle:?
    I've used that and it makes life easy;).
    And spread the cost across 3 Prii and the economics are favorable:).
    Something to consider(y).
    SFO and dig4dirt like this.
