Suggestions for an altimeter?
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Feb 21, 2006.
  1. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I would like to have an altimeter.. I hear the GPS ones are not very accurate anyway.... It would be nice not only to know if you are on truly level ground "which may help explain why your gas mileage is so good or bad"... but its a useful tool I really miss since I don't have it on my watch any more.
    I would prefer a hardwired one so I get a continous readout.
    I am wondering since I'm not alone requesting such a feature, what have people done to solve this?
    If anyone has found a good one they may suggest, I would appreciate it.
    Seems when I shop around.. the only ones I can find are included in the gps's. I don't want to buy a whole gps just for the altimeter and its not that accurate anyway. And I don't want some ugly clunker mounted thing either.
    Has anyone found a nice one that mounts neatly and has hardwire capabilities?
  2. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    While you are looking, take solace in google maps ;)
  3. windstrings
    6,280
    378
    Central Texas
    Whats solace?
  4. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Hubby uses a Casio watch which has a compass and altimeter in it. About $120.
    It only updates every few minutes though.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Get one on ebay out of an old airplane
  6. EricGo
    EricGo New Member
    1,805
    solace |ˈsälis| noun comfort or consolation in a time of distress or sadness : she sought solace in her religion. verb [ trans. ] give solace to. ORIGIN Middle English : from Old French solas (noun), solacier (verb), based on Latin solari ‘to console.’
  7. flynz4
    flynz4 Member
    329
    Portland, OR
    2015 Prius v wagon
    If you want to know how level the road is... it sounds like you would rather have a vertical speed indicator (VSI) rather than an altimeter... although the VSI function could be estimated by watching how fast the altimeter moves.
    I wish that the GPS had an altimeter readout as well. It would be nice to know how much more climbing was ahead until the mountain pass. I would not install a seperate instrument to get this however. It would be nice to have it on my watch.
    /Jim
  8. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    To get an accurate reading of your altitude, you need an altimeter with an adjustable barometric setting. In Aviation this is done with what we call "Kollsman" knob and you read the setting (in inches, mercury) in the Kollsman window. Without such a setting, your altitude reading will change from day to day, in the same geographic place, according to the ambient atmospheric pressure.
    I got a small altimeter with a rotating cover that allows me to set the default barometric pressure. The problem is that the face is only about 2.5 inches in diameter, and the pressure scale is divided into increments too wide to be of any use.
    Put in other words: For every 1000 feet of altitude, the pressure drops (going up) one inch of mercury; the difference in altitude between a reading of 29.90 inches of mercury, and 30.00 inches of mercury is 0.1 inches, or 100 feet. Altimeters sold for use in cars are too small to have a meaningful or readable scale on them, and, as you can see, it doesn't take much of a change in barometric pressure to affect big changes in actual altitude.
    The accuracy of my little car altimeter is about plus/minus 500 feet at best; not very accurate for what you are looking for. To get a correct reading from a pressure altimeter (as opposed to a GPS), you need a source of local barometric pressure. We get that in the airplane from air traffic control, but you can't access that info in a car.
    My Garmin 295GPS unit, however, is much more accurate once I set the altitude (not the barometric pressure). By going to a location, i.e. Boeing Field in Seattle where I teach, where the altitude above sea level is known, I can set the GPS and have it read pretty accurately elsewhere in the city. As long as the GPS can get a signal from enough satellites to do 3D computation, it will give me a reasonable altitude reading, although NOT accurate enough to be used as a primary flight data source unless the GPS is certified for use in instrument conditons.
    Way more of an answer than you expected; hope this helps somewhat. I guess the bottom line is that GPS is better than a mechanical altimeter unless you want to pay huge bucks to adapt some aviation altimeter to your car.
    Bob
  9. daniel
    14,487
    1,518
    Spokane, WA
    GPS units measure altitude in one of two different ways: by a direct satellite reading, or by barometric pressure. Neither one is suitable for your intended use of determining if a road is level.
    The direct satellite reading method does not require any settings, but is extremely inaccurate, because all the satellites are overhead. My hand-held eXplorist told me my altitude had varied by 100 feet as I walked my extremely level jogging route in flat Fargo. The barometric pressure method is probably more reliable, if you have a starting point of known altitude to set it by, or a source for the current pressure. But as noted above, it is extremely imprecise. (Note that precision and accuracy are two very different things.) More expensive GPS units typically use barometric pressure for altitude, while cheaper ones like mine use direct satellite reading.
    What you really need is a surveyor's transit, so you can survey the road in question. Or use the topographic map bundled in the software for some GPS units, which contains altitude data.
  10. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    My little Garmin unit is pretty squirrely when trying to display
    altitude, probably for the reasons given, and can vary up and down
    by several tens of feet just sitting still. But it was accurate
    enough to tell me the ballpark height of the mountains I was going
    over back in December.
    Toyota is reputedly working on a GPS-based efficiency helper which
    would take terrain into account when managing the engine, battery,
    cruise-control, etc. Presumably that would be done via topo
    information mapped to lat/long in the internal database of the GPS,
    as opposed to altitude measurement, especially because it's got to
    be predictive. Cool idea; not sure how much real-life gain can
    be had. Probably depends on how well the driver reads the upcoming
    terrain and tailors right-foot response in the first place...
    _H*
  11. jsf
    jsf Member
    155
    Anytown
    The aviation recommendation is good. You can get the local altimeter settings by purchasing a receiver or scanner that receives air frequencies and monitoring ATIS.
  12. Ken Cooper
    Ken Cooper New Member
    339
    I presume you're looking for a pressure altimeter. Don't know of any available for measuring minor changes in terrain.
    Personally I use a cheap Magellin which seems to work well for what you're describing. Sometimes while on a long drive I'll monitor both the gps and the mpg just for fun and find a definite direct relationship (slow nearly imperceptable rises yield lowered mpg - and vise versa.
  13. MtnTraveler
    MtnTraveler New Member
    29
    Everett WA
    The hiking/climbing community uses wristwatch altimeters. They are plenty accurate for most purposes. Check rei.com or many of the other hiking oriented webpages for examples (Casio, Avocet, many other brands). Most of them have battery-saving options that limit how often the display updates. SOme have fancy gizmos like total elevation gained, dropped (for skiers), etc.
    Of course, you have to set it at a known elevation, due to weather changes.
    If you are always in open terrain (i.e., no trees blocking the view of the satellites, no tall buildings, no cliffs, etc.) than a handheld hiking-oriented GPS can be very accurate. If the terrain is more challenging, you need a GPS that has a quad helix antenna (Magellan Sportrak, for example) instead of patch antenna (Garmin eTrex, for example).
    I've been on many peaks and saddles that are triangulated elevation points, and been well within 50' elevation on the GPS and altimeter watch. Most topographic maps are only accurate to 40' anyway (topozone.com for instance).
    Us peak-bagging fanatics live and breathe by altimeters. Very important tool! I just recently went with the GPS and it's a fun toy too.
    So whatcha gonna use an altimeter for?
  14. windstrings
    6,280
    378
    Central Texas
    yea.. I knew that! :huh:
  15. windstrings
    6,280
    378
    Central Texas
    My Casio watch I used to have would do within 20 ft and was adjustable to match baro differences should you really want accuracy.
    but the decent pressure ones are good within 3 ft.....
    Even one within 20 ft would work for traveling at 60mph.... a digital one would be best.
  16. daniel
    14,487
    1,518
    Spokane, WA
    Boy, o boy, am I ever skeptical of this!!! I checked out REI, and it says the readout on its $170 watch is in 3-foot increments. Do you know the difference between precision and accuracy? BIG difference: Lots of measurement equipment has extremely high precision but much lower accuracy. The watch might give you a read-out in 3-foot increments and yet only be accurate to plus or minus 20 feet, and even that would surprise me.
    My Magellan hand-held GPS displays altitude in very small increments, but appears to be accurate only to within a hundred feet or so.
  17. KTPhil
    KTPhil Active Member
    1,379
    "My Magellan hand-held GPS displays altitude in very small increments, but appears to be accurate only to within a hundred feet or so."
    Actually, 100ft is unusually excellent for a GPS-only altitude reading; it will usually be far less accurate because of poor sat geometry.
  18. Ken Cooper
    339
    Sounds like a cool watch.
    I used my Magellen plugged into my car's power outlet to look at "change" in elevation as I drove (compass too being navigationally challenged). It worked very well for that. Absolute elevation not that important from my perspective.
  19. EricGo
    EricGo New Member
    1,805
    But precision is desired here I'd imagine, rather than accuracy. That is to say, the change in elevation is of interest.
  20. unruhly
    unruhly New Member
    205
    Windstrings,
    Sounds like what you want is an Inclinometer. We used 'em on Submarines. Tiltmeter
    The electronic versions even have accelerometer function built in, but they are probably around 4 to $500.00. Acumar
    Check this out on E-bay: Toyota Inclinometer/Altimiter
    Now if I could just find a periscope, I wouldn't need that backup camera. :lol:
