Sulfur/Rotten Egg smell in winter?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by killertofu88, Dec 30, 2017.
  1. killertofu88
    killertofu88 Junior Member
    32
    Boston
    Has anyone had a sulfer smell with their gen4 Prius after some driving in the cold? This happened a bit last year but stopped once it got warmer out. I have no engine warning lights and my last maintenance and inspection for emissions were fine this past Oct.
    Is this just a normal thing or should I call service about it?
  2. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Some brands of gas in UK have a higher sulphur content than others, which leads to stinky exhaust gases when the mixture is a bit rich, ie when engine is cold.
    killertofu88 likes this.
  3. killertofu88
    32
    Boston
    I was thinking it could be the gas and I should try another station. I just usually go to the closest one to my house. Hmmm
  4. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    May. It I suggest you investigate which brand of gas has less sulphur first. It will help you get rid of the smell first time, if that was the problem, but if it doesn't I'd ask your dealer or friendly mechanic friend.
  5. killertofu88
    32
    Boston
    Good idea, no point in filling up again if the next station is just as sulfur heavy. The one drawback to the Prius is that it’ll take me longer to empty the tank lol!
    According the google searching I did, my best bet is the Shell station pretty close to home, so I’ll give that a shot soon.
    RCO and bisco like this.
  6. Mendel Leisk
    38,729
    Just for giggles pop the hood and look the 12 volt battery over, say that terminals are corrosion-free. Could sulphur smell be from cell(s) going bad in the 12 volt, not sure? Fumes would migrate to air intake at base of windshield.
    Still, I think likely a red herring, gas brand more likely.
    #6 Mendel Leisk, Dec 30, 2017
    RCO, bisco and killertofu88 like this.
  7. bisco
    49,500
    someone else posted this, iirc. don't recall a resolution.
    RCO likes this.
  8. killertofu88
    32
    Boston
    Checked under the hood and the battery connections are clean and so is the rest of the engine bay. I’ll just have to drive it around some more to get rid of the gas and fill up again at Shell to see if the smell goes away.
    RCO likes this.
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Hope that isn't coming from a failed catalytic converter either? Codes supposed to come on computer though
    kithmo likes this.
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Had a similar situation with my Yaris. After the 2nd winter of that smell I decided to stop in at the Toyota dealer. Seems an update to the cars program was available, but only if the customer complained about the issue. May be worth a check if a different brand doesn't fix the problem. Oh, and it didn't cost me anything even though I was out of warranty.
    RCO likes this.
  11. danlatu
    danlatu Senior Member
    533
    1,348
    maryland
    In the winter time engines tend to run rich (more fuel) that fuel tends to burn onto the catalytic converter causing that smell. Driving a car too easy (low rpm) is bad. Drive the car hard every once in a while. I like to floor it once a day @ 5000rpm while getting onto the freeway. It will clear things right up. It is also known as the italian tune up. It also helps keep engine parts free of sludge that sticks to parts from low oil flow.
    kithmo, douglasjre, pilotgrrl and 2 others like this.
  12. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    May be so in a high performance engine, but a low compression Prius.......????
  13. danlatu
    533
    1,348
    maryland
    Prius' 2zr-fxe has a 13.0:1 compression ratio. I know, it baffles me:whistle::whistle::whistle:
    kithmo and RCO like this.
  14. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    On a Gen 4? If so, should be warranty.
  15. Prodigyplace
    11,696
    11,318
    Central Virginia
    On a Gen 4 (2016 at the oldest) that would be highly unusual.
    pilotgrrl and RCO like this.
  16. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I'd go with fuel too.
  17. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    I was thinking of the inlet valve being open for the first part of the compression cycle in an a Atkinson Cycle engine, but yeah!(n)
  18. alanclarkeau
    7,044
    7,584
    Toyota in 2008 said:
    "In the case of the Prius engine , the effective compression ratio is about 8:1, while the expansion ratio is about 13:1. As a result, it is 12% to 14% more efficient, in terms of power output per fuel consumed, than the non-Atkinson engine upon which it is based."
    [ Our Point of View: Atkinson Meets Otto: Why the Prius is So Efficient ]
    douglasjre, danlatu, RCO and 2 others like this.
  19. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    You REALLY need to get it checked out. Exhaust leaks can be deadly in some circumstances.
    You don't run it with RECIRC on in the winter time, do you ??
    And....it is highly unlikely that it is the gas. In most areas, the basic gas stock comes out of the same bulk terminal at the end of a pipeline.
  20. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    I'd be concerned if the car was passing natural gas...
    kithmo, dubit and Prodigyplace like this.
