Summer Tires or All Season Tires?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by smile, Mar 24, 2017.
  1. smile
    smile Junior Member
    37
    Pittsburgh
    2013 Prius v wagon
    My OEM tires have worn out and I need to replace them. Since I have snow tires for the Winter, I'm looking to replace them with summer tires. But I find mostly all-season tires at places like Costco and Tirerack. Will it make sense if I go for all-season tires?
    I have a Prius v Trim Two (sorry if that's not how it should be spelled) which needs 205/60R16 tires .
  2. ETC(SS)
    6,556
    In Pittsburgh?!
    That would be "all season" if I were buying them for a car that I haul my family in......
    There's no good reason not to.
    I get the fact that you have snow tires mounted on separate rims, but I'm thinking that all season tires are better in the wet.
    I might be wrong about that though.
    Your call.
    GOOD LUCK!
  3. Mendel Leisk
    38,736
    "Summer" tires are a dying breed? I think the way to go is all-seasons, supplement by snow tires where warranted.
    49,507
    perpetual summer, where do i have to move to?
  5. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    All season Tyres = no season tyres
  6. Offline
    Offline Active Member
    639
    231
    Lenexa, Kansas
    True summer-only tires are rarely used these days except on high performance / exotic cars. I've bought only two sets of summer tires in the past 25 years and they were for use on unusually fast cars that were electronically speed limited to 150 mph. Those summer tires provided incredibly better handling on dry pavement than all-season tires but they lasted only about 15,000 miles and I went back to using all-season tires in Spring/Summer/Fall.
    We use Bridgestone Blizzak winter tires on our Prius v and Sienna in Winter and all-season tires the rest of the year. These vehicles are "cruisers" and I wouldn't think of looking for summer tires for them.
  7. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    summer tires have better roll resistance, so they should help fuel consumption.
    If you look at a true summer tyre, it has some parts where the rubber is completely uninterrupted when the wheel spins. Usually in the middle.
    on all season tyres the same part is slightly interrupted by thin cuts
    on winter tyres, ALL rubber has deep cuts and much wider than all season (2-3mm), so this way the tyre can grip into snow
    quantumy likes this.
  8. Mendel Leisk
    38,736
    Also the sipes on winter tires are close spaced, the tread is almost like brush bristles. And the rubber stays softer at low temps.
  9. smile
    smile Junior Member
    37
    Pittsburgh
    2013 Prius v wagon
    Thanks everyone. I'll go with all-season tires.
    bisco and Mendel Leisk like this.
