sump plug washer size ??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by graham hendren, Feb 5, 2014.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    i would like to know the size of the sump plug washer inner hole and outter size please
  2. Mike500
    Mike500 Senior Member
    2,593
    766
    Oil pan sump plug ID is 12mm. OD is 20mm.
    graham hendren likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Do you mean the oil pan dump bolt?
  4. graham hendren
    82
    no I mean the oil drain sump plug washer
  5. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    ID hole is 12mm, outer diameter???
    As long as it makes a seal, right? ;)
    SCH-I535
  6. Mendel Leisk
    40,574
    To the OP, just curious why you want to know. Also, any dealership parts department can sell you the Toyota washer for about $1. Buy one and measure it?
  7. graham hendren
    82
    cos im a tight nice person and I want to buy them in bulk ...........i do drive a prius
  8. El Dobro
    El Dobro A Member
    7,075
    3,258
    Buying a Prius does not make you a tight nice person, buying one makes you wise. :D
  9. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    If I buy the Toyota 0W-20 oil and filter at the dealership, they toss in the plug gasket gratis (woo-hoo!!!)
  10. Mendel Leisk
    40,574
    I'm pretty sure the engine oil drain bolt requires 14 mm wrench, going from memory, from last time. That very likely equals 10 mm bolt (at the threads) meaning Rude person's (up the page) is right, saying the washer is 12 ID and 20 OD.
    My 2 cents, when it's oil change I go to the Toyota parts counter and get: one washer, 4 liters oil (occasionally 5, since it can take a tad over 4) and a filter element. It's all on one invoice, helps with the paper trail, at least I like to think so.
    The washers they sell at Toyota (and Honda fwiw) these days have bonded plastic liners, and in my experience these can be trouble prone. With a Honda one in particular, even though I know I've torqued the bolt, often the next time I get to it it seems quite loose. And the plasticky washers can be a pain to get off the bolts.
  11. graham hendren
    82
    well a bit tight
  12. graham hendren
    82
    if anybody would like to know size they are 12mm hole x 20mm outer and 1,5mm depth and they fit very nice . you can buy them in packs of 10 for £1.59 /// Toyota would want that for 1 every penny helps
  13. graham hendren
    82
    spot on
    Mike500 likes this.
  14. qdllc
    qdllc Senior Member
    1,371
    399
  15. PriusLFC
    PriusLFC Junior Member
    Huddersfield
    Sump plug washers.......... Get a Copper washer 12mm Diameter. The engineering part is you want a seal which won't loosen or leak. A copper washer will compress with less torque than the torque required to sufficiently tighten the bolt/Sump plug. You can get 100 for £2.
    Reason I say Copper washer is they use them as air tight seals diesel injectors for a reason....
