Sun Shields?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by RCE1, Jul 9, 2018.
  1. RCE1
    RCE1 Member
    70
    71
    Northern California
    Four Touring
    Please forgive if this is a well known subject. I have to park out of my garage for a while and live in a warm area. I went to NAPA and bought a solar shield that said it was good for the Prius, but it doesn't fit well at all. I want to take it back and get one that fits instead. I have a Gen 4 Touring and was just wondering which of the many sun shield products available fit well in the Prius?
    Thanks.
  2. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    #2 fmerkel, Jul 9, 2018
  3. Prodigyplace
    12,678
    11,830
    Central Virginia
    Gen 4 was a total redesign including a different chassis. I doubt Gen 3 would fit. That is why there is a separate Gen 4 category here.
  4. Mendel Leisk
    41,905
    I'd be thinking about one of those canopies you can drive the whole car under; UV is tough on so much, the headlights for example.
    Is it impossible/impractical to clear space in the garage? That'd be my number one solution.
  5. Adam1a
    Adam1a Member
    50
    59
    Three Touring
    I have a Covercraft UV11447SV that I purchased from Amazon. I fits great and doesn't interfere with the mirror, scangauge II, radar detector, or front camera. The sun visors helps hold it in place and it folds up nice.
  6. RCE1
    RCE1 Member
    70
    71
    Northern California
    Four Touring
    The Sun Visors Hold It Up. Duhhh. I've never owned one of these before, of course, and I'd not considered the visors. Silly me.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I definitely need an external one because I have a dash cam to take into consideration. I'm just afraid somebody will walk by and swipe it.
  8. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    Mine has tabs that are closed in the door on both sides. Possible to yank it out or cut it I suppose. OTOH it's not all that expensive an experiment.
  9. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    What if it rains?
  10. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Once the sun's rays enter the car through the glass the heat is trapped inside. An external cover makes a lot of sense, but no matter what you use, eventually the car will become the same temperature as the air around it. Where I park, that is over 110 degrees through the summer months.
    pilotgrrl likes this.
  11. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Check PriusChat shop - ie support PriusChat:
    Incidentally, if you use an external one, they're fine as long as you don't do what an ... acquaintance did. It had rained and he spread it out across his bonnet/hood to dry before he put it inside. The water underneath it and the heat of the sun cooked the paint and it bubbled. Whoops. But that's a problem with an external one if you use it away from home - and it's wet, you have to put it inside wet.
  12. William Redoubt
    1,228
    1,173
    Rain is seldom a problem in the land of solar power and high taxes.
    krmcg and alanclarkeau like this.
  13. Tideland Prius
    16,621
    Sunshade HeatShield for 2016-2018 Toyota Prius - Front - PriusChat Shop
    We've had it for the Gen 2, 3, and 4 Prius as well as my smart fortwo. They work well and are a custom-fitted size.
    alanclarkeau likes this.
  14. fuzzy1
    10,603
    That would be a LOT cooler than a normal closed car baking in the sun.
    Even when an inside shade helps reduce the temperature rise, it will still be higher than an external shade.
  15. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    i like the Heatshields bought from the Priuschat shop. (Front & back) I've used them every day for 2.5 years. The front one is just now starting to get floppy and loose. The heat got to it! :ROFLMAO: Almost 100 degrees every day. Probably 110 inside the car. Even with dark tint.
    I'm glad I bought 2 of each. :)I got spares.
  16. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Take a look to see what's available in ye olde PriusShoppe, I have screens for both front and rear, and their regular use makes the interior much more habitable, as well as being much better for the TractionBattery (see other threads) - hope this helps - Wil
  17. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    I have used a Covercraft front window cover in each of my vehicles for a long time. In South Carolina these window covers are essential. The Covercraft window cover does an outstanding job of keeping solar heat out of the car and is worth every penny of the $50+ cost. The Covercraft is made from a thick honeycomb material with a reflective material on the front. If you are careful putting them in and out of the window they will last many years. It’s not a flimsy piece of junk like what you get at Walmart. Each Covercraft is made for your vehicle...not a one cover fits every vehicle made.
    I can’t recommend the Covercraft highly enough.
    With my windows tinted to the SC state legal limit and the Covercraft front window cover my interior stays as cool as possible.
    #17 Jon Watkins, Jul 10, 2018
    Adam1a and WilDavis like this.
  18. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    It gets wet. :rolleyes: Shake it off, fold it up, throw it in the trunk.
    Note, the external cover is a distinct advantage for snow or frost. Peel it off and you are good to go....except for the other windows.
    It came nicely folded in a cute bag. You would need the skill and patience of an experienced packer to put it back in. Doubt it will ever see the inside of that bag again.
  19. Prodigyplace
    12,678
    11,830
    Central Virginia
    Your Prius has a trunk?
    Mine has a carpeted cargo area that is an extension of the passenger compartment.
  20. Mendel Leisk
    41,905
    Maybe the OP's busy cleaning out his garage? :whistle:
