Sun visor extension needed
Discussion in 'Prime Accessories and Modifications' started by GLouderback, Apr 21, 2017.
  1. GLouderback
    GLouderback Member
    Lower Merion PA
    The sun visor in any Prius is useless when the sun comes in on the drivers side window. Toyota should design some sort of extension into there sun visors. I rigged up a smoky plastic piece held on by rubber bands, but I would surely like something more elegant then that. Any ideas out there?
  2. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    below is what i have been using since 2012 in my 1st Prius, not really elegant but does it's job in lieu of Toyota having a real solution ... and i understand from many comments on this site that this has been brought up to Toyota for many years (and models) with ... nothing
    If the link doesn't work, search on amazon...
    1 pair Gray Visormates Sun Visor Extenders to fit 2010 and newer Prius
    sonomac, bisco, GLouderback and 2 others like this.
  3. GLouderback
    GLouderback Member
    Lower Merion PA
    Thanks so much. Looks like my jury rig but with better rubber bands. Will order it.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Just ordered mine, got a reply back from Visormates asking me what year is my Prius, then got another reply saying they will ship tomorrow:D
  5. bisco
    51,141
    i need to order one as well, to replace my cardboard and rubber bands.:oops:
    priuscatprimeguy likes this.
  6. joachimz
    451
    612
    17
    SoCal
    interesting, i ordered mine for the Gen3 and they seem small for the Prime, when you receive them, would you mind measuring and posting here? i might order new ones if they're bigger
  7. priuscatprimeguy
    2,730
    2,640
    ok
  8. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Bought a pair 2 months ago. Very good. Just tell the company that you have a 2017 prius prime. Shipped 2nd day.
  9. priuscatprimeguy
    2,730
    2,640
  10. GLouderback
    GLouderback Member
    Lower Merion PA
    5x12
  11. GLouderback
    GLouderback Member
    Lower Merion PA
    5x12
  12. bisco
    51,141
    i wish they made one with a flip down tinted plexiglas to cover more below.
  13. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    = sunglasses
  14. joachimz
    451
    612
    17
    SoCal
    Thanks ... my existing ones are 4x12 so I'm going to order a new set
  15. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Ordered mine today as well.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I just now got around to taking pictures of my solution. Made from 1/8" plastic. Wrap around, so no straps. I used a small nut and bolt covered by the plastic tip from metal wire shelving for the little white handle. Then glued on some felt that was a near perfect color match.
  17. bisco
    51,141
    well done jerry!
    jerrymildred likes this.
  18. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I know this is really old (sorry) but how did you get the plastic to curl around the visor? Heat gun or something?
    Nice solution.
  19. jerrymildred
    11,517
    14,137
    Tampa, FL
    Yes, heat gun. I used a wooden broom handle for the form. Took lots of trial and error.
