Sunroof Drains Location?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Cortega315, Aug 30, 2023.
  1. Cortega315
    Cortega315 New Member
    Pawtucket, RI
    Hello All,
    I have a 2010 Gen 3 Prius with sunroof/solar panel. I am getting leaks through both driver/passenger sun visors whenever it rains really bad, or when I go through the car wash.
    I have figured it to be the sunroof drains are probably clogged but I cannot locate them for the life of me.
    Does anyone have a diagram or even better, a picture of these drain holes? I've tried looking all over and don't really see anything.
    Thanks!
  2. Bill32803
    Bill32803 Junior Member
    27
    Orlando Florida
    Did you figure out what was up with that. I have a deteriorated ''hinge'' cover on the front of my sunroof. Want to get it replaced. Worried it might be a huge job for something so minor.
  3. ChapmanF
    15,622
    It is, if I'm not mistaken.
  4. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    @Cortega315 I see you've already posted in the old 8 page thread about the issue. And what I believe @fuzzy1 has described in that thread are 2 (small channels) that lead from the sunroof to the windshield drain channels, that he scrapped clean using a pointy tool. He also mentioned that he's not sure those tiny grooves he cleaned are actually water drain channels. @Markee posted that he recently ( 2022 ) had 2 different glass installers search for drain holes and neither of them found any drainage tubing even after pulling many of the interior trims and headliner off.
