Sunroof Noise
Discussion in 'Gen 3 Prius Main Forum' started by cibby, Jun 2, 2009.
  1. cibby
    cibby New Member
    San Francisco, CA
    I'm eagerly waiting to test drive a Prius with the sunroof package. I haven't seen much feedback from new owners on how loud it is when driving at high speeds (i.e. on the freeway). Can folks who have been in one provide feedback on the noise level? Would you say it's quieter, about average, or louder than most?
    Thanks!
  2. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Also, how much of hit on the mileage with the roof open?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Being a bigger opening, I'd say it's slightly louder, but it's been quite a while since I've had a moonroof/sunroof (2001) on a car I drove regularly.
  4. cibby
    cibby New Member
    San Francisco, CA
    How is the wind noise? I find some sunroofs are so loud that you really don't want to drive with them open on say the freeway. It doesn't sound all that bad from your post. If you can provide any more info that would be great.
    Thanks!
  5. HTMLSpinnr
    5,339
    917
    251
    I opened it up tonight because it was only 84°F outside on the way home. I noticed more noise when I had the side window down than when I had the moonroof open.
  6. global
    global Junior Member
    Maryland
    Beyond just wind noise-how is the roof noise with audio going? I like the idea of a sunroof - I have one in my Jeep Liberty-and I stopped using it because with it open I could not hear the radio or anyone in the car talking. I don't want to repeat that mistake. I realize the Prius moonroof is a much different design-but still worth checking.
    Thanks for anyone's response.
  7. avian
    avian New Member
    33
    Houston, TX
    I can still hear the radio fine if I open the sunroof, however I only open it to the first position (tilted up) if I'm on the freeway. If it's open all the way its like having a window open.
  8. njmurvin
    njmurvin Member
    103
    Simi Valley, CA
    I haven't played with it a lot. But, it was pretty noisy at freeway speed. It was all the way open. Didn't have the radio on so I can't comment on that.
  9. silverfog
    silverfog New Member
    152
    23
    Raleigh,nc
    Not as noisy as most retracting sunroofs.The two angled blades on the open sunroof not only minimize wind resistance but also reduce noise. It;s quieter to have only the sunroof open than a window open, but, yes, you do have to turn up the volume.
  10. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    The sun roof sucks
    It is very loud compared to my pick up truck
    Any sun roof that slides on out of the roof are noise compared to a sun roof that slides into the roof
    The only good thing is it lets in more light and you get the ventilation fan
  11. silverfog
    152
    23
    Raleigh,nc
    Ah, a contrary opinion! We really need a comparative decibel test. I believe that the Prius design, minimizing wind resistance, also reduces noise, but I'd love to see this tested.
  12. AussieDave
    AussieDave New Member
    Melbourne Australia
    With it open to the first stage (back lifted up) you can hear some wind noise but it is not intrusive even at highway speeds,
    Open it all the way and as the roof section retracts externally the wind noise levels do rise and the audio volume needs to be turned up a little. Very little turbulence gets in to the cabin however.
    We have just had an aftermarket unit fitted to mother in laws Nissan Micra. Compared with it the only feature I find missing on the Prius unit is the automatic opening and closing of the sunshade.
    David
