Super Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ScottY, Jun 9, 2006.
  1. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Super Battery
    06.08.06
    Ever wish you could charge your cellphone or laptop in a few seconds rather than hours? As this ScienCentral News video explains, researchers at the Massachusetts Institute of Technology are developing a battery that could do just that, and also might never need to be replaced.
    The Past is Future
    As our portable devices get more high-tech, the batteries that power them can seem to lag behind. But Joel Schindall and his team at M.I.T. plan to make long charge times and expensive replacements a thing of the past--by improving on technology from the past.
    They turned to the capacitor, which was invented nearly 300 years ago. Schindall explains, "We made the connection that perhaps we could take an old product, a capacitor, and use a new technology, nanotechnology, to make that old product in a new way."
    Rechargable and disposable batteries use a chemical reaction to produce energy. "That's an effective way to store a large amount of energy," he says, "but the problem is that after many charges and discharges ... the battery loses capacity to the point where the user has to discard it."
    But capacitors contain energy as an electric field of charged particles created by two metal electrodes. Capacitors charge faster and last longer than normal batteries. The problem is that storage capacity is proportional to the surface area of the battery's electrodes, so even today's most powerful capacitors hold 25 times less energy than similarly sized standard chemical batteries.
    The researchers solved this by covering the electrodes with millions of tiny filaments called nanotubes. Each nanotube is 30,000 times thinner than a human hair. Similar to how a thick, fuzzy bath towel soaks up more water than a thin, flat bed sheet, the nanotube filaments on increase the surface area of the electrodes and allow the capacitor to store more energy. Schindall says this combines the strength of today's batteries with the longevity and speed of capacitors.
    "It could be recharged many, many times perhaps hundreds of thousands of times, and ... it could be recharged very quickly, just in a matter of seconds rather than a matter of hours," he says.
    This technology has broad practical possibilities, affecting any device that requires a battery. Schindall says, "Small devices such as hearing aids that could be more quickly recharged where the batteries wouldn't wear out; up to larger devices such as automobiles where you could regeneratively re-use the energy of motion and therefore improve the energy efficiency and fuel economy."
    Schindall thinks hybrid cars would be a particularly popular application for these batteries, especially because they are expensive to replace.
    Schindall also sees the ecological benefit to these reinvented capacitors. According to the Environmental Protection Agency, more than 3 billion industrial and household batteries were sold in the United States in 1998. When these batteries are disposed, toxic chemicals like cadmium can seep into the ground.
    "It's better for the environment, because it allows the user to not worry about replacing his battery," he says. "It can be discharged and charged hundreds of thousands of times, essentially lasting longer than the life of the equipment with which it is associated."
    Schindall and his team aren't the only ones looking back to capacitors as the future of batteries; a research group in England recently announced advances of their own. But Schindall's groups expects their prototype to be finished in the next few months, and they hope to see them on the market in less than five years.
    Schindall's research was featured in the May 2006 edition of Discover Magazine and presented at the 15th International Seminar on Double Layer Capacitors and Hybrid Energy Storage Devices in Deerfield Beach, Florida on December 2005. His research is funded by the Ford-MIT Consortium.
    http://www.sciencentral.com/articles/view....le_id=218392803
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I've often wondered what are the advatages/disadvantages of Lithium versus capacitors (such as these nanotube ones)?
    No memory effects for either...faster charge for caps...longer life for caps...more controlled and longer discharge for Lithium, meaning caps would be great for quick bursts, lithium good for a lengthy discharges?
    Any other insights here?
    With ALL the newer battery tech that is here now and up-coming, I just can't see where hydrogen will compete, especially when u do the energy requirements math...
    cheers,
    Curt.
  3. Screwdriver
    Screwdriver New Member
    45
    In 30 years we will all look back to vehicles that prompted the advances in electric propulsion and storage. Vehicles like the Insight, Prius, the Segway and your everyday Electric scooter.
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(finman @ Jun 9 2006, 11:49 AM) [snapback]268614[/snapback]</div>
    When I talk to my friends about improving current Prius hybrid system, I was thinking along the same lines. I am sure someone already has this idea, I proposed using both ultra capacitors and lithium in the new hybrids such that the capacitors will provide quick bursts of charge and discharge, while the lithium battery will provide the storage capacity.
  5. etyler88
    etyler88 etyler88
    450
    Dover, DE
    That's and exciting idea. You won't see it in five years though.
  6. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
    The discharge rate of a capacitor is controllable by the amount of resistance or load placed in series with it. Our familiar concept of the capacitor as a "quick discharge" element is based on the fact that the capacitances previously available were small. Peak power output is a function of how fast you can discharge a capacitor, and so far, in cases like xenon flashtubes, the capacitances have been very small.
    However, breakthrough announcements like these are essentially saying "we believe that we have raised the capacitance of these capacitors to a level where their storage capacity is essentially the same as batteries." That is, charge one of these capacitors to 12V, and you could essentially discharge it at the same rate as a you could discharge a standard 12V battery over the same amount of time. The implications of this are astounding, as I see it, as capacitors like these will eliminate batteries.
    What you bring up about the quick discharge rates of capacitors is, of course, true. However, if you were to try to discharge one of these capacitors as quickly as, say, a photoflash capacitor, you would end up with what would likely be something like Mega Watts of power - seriously. I'm not going to go into all of the formulas as there are many sources of them available, and if you doubt what I am saying, I encourage you to play with the math a bit and see for yourself. An example (not based on the actual discharge rates of real automobile batteries) of how to approach it might be to calculate the total energy capacity of a battery like this:
    12.6V nominal voltage, times 2 Amperes for 2 hours. This is 50.4 Watt-hours. Now, multiply by the number of seconds in two hours, i.e., 7,200: gives 362,880 Watt-seconds. The Watt-second is equivalent to the Joule. The formula for the energy storage of a capacitor in Joules is (1/2)*(C*V^2) where C is in farads. If you solve for C, you get the capacitances that these researchers are talking about. These capacitances are huge compared to what was previously attainable.
    If you were to discharge a capacitor with the equivalent capacitance as this example in 0.3 seconds, your peak power would be slightly in excess of 1.2 Mega Watts, i.e., 1,200,000 Watts. This is a huge amount of power (over 1,600 horsepower) :eek: , and most electronic systems would never be able to handle this amount of power in an instantaneous surge. I think that it is highly likely that a capacitor with this level of storage would almost certainly never be used in a manner that would allow this type of power discharge unless it were being used in weaponry.
    My point here is that while capacitors are capable of providing quick discharges and high peak powers, these capacitors would almost certainly never be used in a manner where they would be discharged like a photoflash capacitor (outside of a military use, of course). Their main advantage (other than quick charge times, the complete lack chemicals, and practically infinite lifetime) is their capability to store large amounts of potential energy that will then be used relatively slowly over time in a manner similar to the way a battery is used (although they do have that added bonus of being able to supply high peak powers (more so than batteries can) when necessary).
    Much agreed. IMHO, hydrogen is not the way to go as I see it.
  7. bobr1
    bobr1 New Member
    306
    Portland, Oregon, USA
    Has any team investigated the long-term effects of the introduction of carbon nanotube structures into our environment?
    I love the ideas that have cropped up recently in nanotechnology, but I have to wonder... The carbon nanotube structure is relatively benign and extremely strong, but it is also difficult to break the structure apart and destroy it once formed... carbon nanotubes do not biodegrade, do not break down in water, etc.
    If in 100 years our technology incorporates carbon nanotubes into every type of device, even just as a storage battery, surely significant quantities of discarded nanotube products will wind up in our landfills, in the air, and in our environment.
    Does the body expel nanotube fragments that are inhaled? Or do they lodge into our tissues, never to be degraded? Does it matter?
    I ask this not to be a naysayer, but to be proactive. Nanotubes offer us the potential of great advances in engineering, from energy efficiency, size, and strength in many products. But are we equipped to handle the consequences (if any) of nanotube production on ourselves and the environment?
    - Bob R.
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Screwdriver @ Jun 9 2006, 09:30 AM) [snapback]268636[/snapback]</div>
    Cough*EVs*cough
    THE vehicles that brought us the NiMH chemistry might just BARELY be remembered if people actually knew they existed. One day not long ago, we had actual BATTERY cars. We've now stepped way back and are powering our battery cars with gasoline. Please don't forget the *real* battery cars! We'll be back there soon enough, and the pioneer vehicles will hold a dramatic place in automotive history.
  9. smackoww
    smackoww Junior Member
    60
    umm, its been a while since physics, but all they're doing is increasing a capacitors capacity (no pun).
    capacitors dont hold a charge for very long (leave the car with charged caps off over-night, the cap will be depleted.)
  10. bobr1
    bobr1 New Member
    306
    <div class='quotetop'>QUOTE(smackoww @ Jun 9 2006, 12:06 PM) [snapback]268730[/snapback]</div>
    It's been awhile for me, too, but I thought that some capacitors made from certain types of material exhibited little or no leakage.
    Once the energy is store in a capacitor, if it is disconnected from a circuit completely, wouldn't the only way for energy to escape be via heat or ionization? (Warning, warning, getting way outside my degree field...)
    I had another question about these new extra-super-capacitors: Is it possible to construct a capacitor in such a way that sudden complete discharge is nearly impossible (for safety) but that rapid charging is still possible? In other words, if you incorporated multiple stages of current limiting resistors or some other technique throughout the capacitor, so that puncturing it or shorting it wouldn't cause a total and immediate discharge, can you still allow the capacitor to rapidly accept a charge? Perhaps using a layer of semiconductor acting as a diode? (A little knowledge is a dangerous thing... sorry if I'm way off base here.)
    - Bob R.
  11. Godiva
    Godiva AmeriKan Citizen
    10,339
    I predicted in an eaten-long-ago-by-a-forum-crash post that there would be new and fantastical advances in battery technology. Necessity being a mother. No reason to with an ICE car. But with hybrids...every reason to improve them.
    And when the batteries are developed for cars....the plug in becomes very VERY viable.
  12. MikeSF
    MikeSF Member
    416
    San Francisco
    A physicist to the rescue!!! Of course I really dont know much about nano-crystal physics *grin*. The way people have made large capacitors in the past have been to put dielectrics of various materials inbetween, this allows you to get more storage for a give size. But I'm curious if you start upping the capacitance too much especially if its using a trick by using a large surface area of lots of tiny things (nano-tubes/crystals/monkeys) will there be an issue of arcing that occurs?
    Large capacitance = large electric field (at full charge) doesn't take much to get arcing to occur (potential difference of 10kV per cm in dry air IIRC)
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    <div class='quotetop'>QUOTE(bobr1 @ Jun 9 2006, 01:59 PM) [snapback]268695[/snapback]</div>
    Can they be recycled into roadbeds? Flexible for tires?
  14. bobr1
    bobr1 New Member
    306
    <div class='quotetop'>QUOTE(DeadPhish @ Jun 9 2006, 03:12 PM) [snapback]268889[/snapback]</div>
    Well, when you are talking about carbon nanotubes, they are microscopic and once they are sheared or severed, they do not tend to adhere to anything, and are harder than diamonds.
    Here is a Wikipedia entry on carbon nanotubes:
    http://en.wikipedia.org/wiki/Carbon_nanotube
    - Bob R.
  15. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(bobr1 @ Jun 9 2006, 06:18 PM) [snapback]268891[/snapback]</div>
    imagine the days when we'll be breathing carbon nano tubes.... :blink: :eek: :wacko:
  16. benighted
    benighted New Member
    530
    Westport, WA
    <div class='quotetop'>QUOTE(ScottY @ Jun 9 2006, 06:56 PM) [snapback]268962[/snapback]</div>
    "Fullerenes and carbon nanotubes are not necessarily products of high-tech laboratories; they are commonly formed in such mundane places as candle flames."
    It looks like you don't need to imagine it..
  17. MikeSF
    MikeSF Member
    416
    San Francisco
    <div class='quotetop'>QUOTE(benighted @ Jun 9 2006, 11:20 PM) [snapback]269085[/snapback]</div>
    Scrape the back of a used fireplace with your finger... if you looked under an uber-high powered microscope you'd see millions of carbon nanotubes under your finger nail :)
  18. bobr1
    bobr1 New Member
    306
    <div class='quotetop'>QUOTE(MikeSF @ Jun 10 2006, 06:44 PM) [snapback]269353[/snapback]</div>
    Well, OK, that's why I was asking about them as a question... if they are that common, I'll (mostly) stop worrying.
    Still, it's not hard to come off with the impression that they're something completely new and different, given the mainstream press coverage.
    - Bob R.
