Super Fuel Saver
Discussion in 'Gen 2 Prius Fuel Economy' started by gsipos, Nov 18, 2005.
  1. gsipos
    gsipos New Member
    Anyone every buy and use the Super Fuel Saver with their Prius? Did it help improve gas mileage or is it just fancy marketing?
    On the site http://sigmaautomotive.com/ it states:
    Super Fuel Saver is a magnetic frequency resonator. By way of its Neodymium super conductors it generates the specific resonance frequency that, when installed over the fuel line, will fracture the hydrocarbon chains in the passing fuel. No magnet, no matter how large, can produce the required flux pattern, and yet be versatile & flexible enough in size to fit virtually all installations. Theoretically, when fuel molecules get exposed to the specific resonance created by the Neodymium, combustion becomes more efficient, translation: Fuel is burned more thoroughly while un-burned pollution (in the form of exhaust) is reduced
    Let me know
  2. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Thanks for the smile.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    If you buy one of those, let me know I hace some ocean front property in Arizona you might be interested in!
  4. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    At least they named a good magnetic material, but look up Superconductivity and note that when they talk about "low temperatures" they generally mean "temperatures approaching absolute zero"
    I am very wary of produsts like this - especially the $50+ ones.
    Oddly enough, Neodymium can be used to clean exhaust, or at least as a component in an assembly that does so.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Hmmm. I do a lot of industrial programming in the petrochemical field. By "fracture" is that like cracking or like reforming? So by breaking the C-C molecular bonds, we're making .... ethylene?
    If anybody is interested, I have a very large bridge for sale.
    Cheap.
  6. altaskier
    altaskier New Member
    157
    Long Island, New York
    It's complete baloney.
    Rare earth magnetic materials like Neodymium or Samarium make much stronger static magnetic fields than Iron magnets. As pointed out by others, this has nothing to do with superconductivity, and unless you somehow spin the magnets there's going to be no frequency to the magnetic field.
    Ok, so you could go to www.edmundscientific.com and buy a few rare earth permanent magnets (which, as pointed out by others, have nothing to do with superconductivity) for cheap and duct-tape them to your fuel line. So what? You're not going to fracture any molecular bonds from having molecules go past a static magnetic field.
    This advert demonstrates the idea that a little knowledge is a dangerous thing in the hands of marketers. Let's consider the case of a medical magnetic resonance imaging machine (MRI scanner). It uses superconductors to produce a very large static magnetic field. It pumps in radio power at a resonant frequency for a particular atom type in the particular static magnetic field. However, it does no molecular chain breaking (otherwise you'd have the same limitations on ionizing radiation dose that x-ray systems such as CAT scanners have). But hey, it involves magnets...
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    P.T. Barnum was right! God bless him.
