Superseded rear brakes 2013 prius V?
Discussion in 'Prius v Technical Discussion' started by davran, Mar 2, 2021.
  1. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    Hello all,
    I just got a second Prius (a '13 V), and dealer said it needs rear brakes.
    I've read that the V brakes of '12 - '13 had problems and were subsequently improved. One article says that Lexus CT200h rear brakes are the fix; is this true?
    If there's a superseded rear brakes part# for the early Vs I can't find it.
    Thanks, David.
    #1 davran, Mar 2, 2021
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,016
    6,903
    Texas Hill Country
    The brake master cylinder and pump have problems and cost $2200 to replace at a dealer if the special customer support program does not cover them. My rear brakes are original at 250,000. They only suffer from driver habits occasionally.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    See Toyota bulletin T-SB-0081-13 Rev2, “Rear Brake Groan or Squeak Noise when Cold” (PDF), January 28, 2014.
    This has been discussed in many PriusChat threads; search for T-SB-0081-13.
    vvillovv and davran like this.
  4. Mendel Leisk
    42,277
    I know on reg Prius they just beveled the corners of the pads a bit more, reducing the when-new contact area. Not sure how effective that would be. And it would accelerate wear I think.
    Talk to dealership parts dept person; see what they say.
    How many mm have they got now, btw?
    davran likes this.
  5. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    I pulled apart the V's rear brakes this morning, and I didn't realize they're a top-hat design for the parking brake.
    Like the fronts I pushed back the caliper pistons, lubed the sliders, and for the rears I adjusted the parking brake.
    All done, and no brake noise so far :) I forgot to deglaze the pads, so they might be coming apart again in awhile.
    Tim Jones and vvillovv like this.
