Supposed inverter replacement. Had a check hybrid system warning on the display.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Jul 2, 2015.
  1. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    I have a 2010 Prius with 161k on it and they called me saying it might be the inverter. Asking for labor approval to determine final reason.
    I am mechanically inclined but I haven't been unable to find anyone talking about having done it. Looks like unbolt and replace.
    SM-N910V ?
  2. JC91006
    16,674
    8,519
    There was a recall on the inverter
    51,155
    ask them for the codes first.
  4. mrbigh
    3,686
    699
    Long Island, NY
    I would insist on the Inverter failures recall....................
  5. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Yeah, well they asked for 585 dollars in diagnosis fees leading me to believe they aren't going for the recall.
    SM-N910V ?
  6. JC91006
    16,674
    8,519
    You can get a used inverter for about $300 or less.....and install it yourself. $585 to diagnose? I suggest you go get your car back and bring to their attention the recall if you haven't done it.
  7. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Yeah, I've seen a couple on eBay. So it really isn't difficult? I'm going to call now.
    SM-N910V ?
  8. JC91006
    16,674
    8,519
    installing an inverter is pretty straight forward if you have some basic mechanic tools. There should be tutorials online.
    But I think step #1 is to determine if the Inverter is at fault for your problems....and it shouldn't cost $585 to do it
  9. mrbigh
    3,686
    699
    Long Island, NY
    My approach would be to get in contact with Toyota customer care services. You should be covered under the recall and your money refunded or credit it to you
  10. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    So they call me back 24 hours later and inform me that it wasn't doing it anymore. And that they wanted to keep it till morning to see act up again. It didn't. I didn't mention before that they had it the week before because I thought it was prob unrelated. But maybe not, Idk.
    They ended up not charging me anything. Which I suspect that something may not have been plugged back in all the way from the previous service visit. But that's just speculation.
    SM-N910V ?
  11. Mendel Leisk
    40,586
    Did you have the recall done?
  12. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    The only recall I've had done was the software update for the fan on the battery. As far as I have been told by the dealer that's the only recall.
  13. JC91006
    16,674
    8,519
    Strange it went from $585 diagnostics to zero.
  14. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Right! They also tried to infer that the DEi remote start may have caused the problem and people shouldn't do that because the high voltage could kill them. This guy who called me and said that was different than the original service writer who I've dealt with on any other service issues. I kinda laughed at him and said, "you mean to tell me that 240v or whatever it is exactly can pass through that wire that's designed to maintain .5v without melting it first?" Just to get him to calm down on trying to rape my wallet.
  15. Mendel Leisk
    40,586
    The only software recall was inverter related, to protect it better during hard acceleration. So likely there's just some confusion regarding recall description, but you have had the "inverter" recall.
  16. JC91006
    16,674
    8,519
    With the recall done, they've most likely extended your inverter warranty to 150k miles, which you seem to be over now.
  17. mrbigh
    3,686
    699
    Long Island, NY
    Seems that the "problem" ended with a "Happy Ending" .:rolleyes:
    mypriuscious likes this.
  18. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    A bit of follow up. Problem came back this past Monday. Back to dealer, a relay block went bad. Which, per Toyota, typically happens from idling to much?
    The service writer had told me that when the other guy called me it was because he had an emergency trip to the dentist and it wasn't clarified that the diag was free.
    I also discovered that they hadn't even put a scanner on it yet when the service manager called me to tell me diag fees. What a schmuck.
  19. JC91006
    16,674
    8,519
    This car actually doesn't idle much
  20. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    They had to call Toyota for assistance and that's what Toyota said. That they've typically only seen it in hybrids that are taxi's.
