Survey: date; odometer; battery kWh; temperature
Discussion in 'Prime Technical Discussion' started by bwilson4web, Aug 6, 2018.
  1. bwilson4web
    15,518
    I've noticed my 2017 Prime no longer takes as much charge as it used to. I still have 25-27 mi range but this appears to be down from 28-30 mi. Now I have just one Prime but need a larger sample set from the community.
    PROTOCOL
    1. Run the car in EV mode to "--%" SOC.
    2. Connect to L1 or L2 charger that records the "kWh"
    REPORT
    1. Record date.
    2. Approximate odometer miles (or km).
    3. Battery kWh to 100% from EVSE or Kill A Watt, e.t.c.
    4. Ambient temperature at start.
    Thanks,
  2. padroo
    padroo Senior Member
    2,763
    2,250
    Could it be the hot summer heat?
  3. bwilson4web
    15,518
    "Plug-In" "Plug-Out" "Energy (kWh)" "Charging Time" "Temp"
    "1:34 AM 8/6/2018" "Still plugged in" "5.96" "01:51:05" "72" ~12,050 mi
    "3:08 AM 8/5/2018" "11:54 AM 8/5/2018" "5.95" "01:53:58" "78" ~12,010 mi
    "3:43 AM 8/4/2018" "3:51 PM 8/4/2018" "6.16" "01:54:59" "73" ~11,950 mi
    L2 charger at maximum amps, ~14.5 A.
    Is there a forumla to know the cost for each Empty-Full EV charge? | PriusChat
    2/26/17 11:07 AM 6,35 kWh "2:08"
    2/23/18 12:15 PM 6.33 kWh "2:08"
    Prius Prime Plus in my hands | Page 7 | PriusChat
    01/19 /17 02:00 AM 6.3 kWh ~28F
    #3 bwilson4web, Aug 6, 2018
  4. bwilson4web
    15,518
    The point of the survey is to identify the dependent and independent factors.
