Suspension Break-In
Discussion in 'Gen 3 Prius Main Forum' started by erikl, Mar 31, 2011.
  1. erikl
    erikl New Member
    36
    SF Bay Area
    Is it just me, or is the suspension on my Prius II relaxing and breaking in? I used to run 38/36 and could barely tolerate the harsh ride over our awful roads, but with 5K on the odometer and running 46/44 things are currently feeling remarkably composed.
    In my head, or has a few thousand miles of travel on the springs/shocks loosened things up?
  2. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Could you have a bad strut? I don't think there's anything to loosen up. Does the car feel like it sways/rocks up and down or side-to-side?
  3. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Tire pressures have a big impact on the ride characteristics.
    If you reduce the pressures back to 38/36, does the harsh ride return ?
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    ... How would the ride get harsher with less tire pressure.
    I'm thinking the OP got used to the car/ some parts may break in some and provide a better ride.
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I don't think the suspension gets softer with use, but perhaps you have found the most comfortable seat position for your ride and have become more accustomed and tolereant of the unique characteristics of your Prius. On the other hand, it could be that your lower fuel bill has added more padding to your wallet, shielding you from some of life's bumps in the road. Regardless of the reason, it's nice to know that your Prius ride has gotten better with use.
  6. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I think that the Prius suspension does require some break in period. AFTER ABOUT 5000 MILES, THE RIDE DID BECOME SMOOTHER AND MORE COMFORTABLE.
  7. erikl
    erikl New Member
    36
    SF Bay Area
    Thanks for the replies guys. I just had a 5k service, everything checked out suspension-wise. I'm pretty sensitive to ride characteristics -- I was stunned when the Prius, new, felt harsher at stock psi's on tiny 15" rims than the 20yr old car it replaced, which had a double wishbone suspension setup on deeper rims.
    The solid beam setup doesn't help this car, but then I forget that this is a vehicle that has had a lot of amenities and small touches zapped in order to meet pricing criteria.
    Did some searching on the forums, and found that others had reported similar changes in ride quality. For now I'm chalking this up to suspension break-in!
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Based on the ride your avatar, I'm going to guess that you aren't the right person to evaluate whether or not the Prius ride is smooth enough for people with delicate derrieres.:D
  9. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    That would depend on what the OP meant by a harsh ride.
  10. Mendel Leisk
    40,574
    I've heard it said that if you could instantly transport from your brand new car, say to 5 years later, you would notice a suspension difference. Typically happens very gradually, so you get used to it, don't notice.
