Suspension clunk after Control Arm and Sway Link replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frogblast, Jan 30, 2020.
  1. Frogblast
    Frogblast Junior Member
    CA
    My 2006 Prius, with 240K miles finally got around to needing a bunch of suspension components replaced.
    I started with the driver side lower control arm and sway bar link. A couple days later, I noticed a clunking sound start, intermittently happening once when starting pressing on the accelerator, and happening once when starting pressing on the brake. It is intermittent, sometimes a turn can encourage it, sometimes it doesn’t. It sounds as if something is moving between two positions.
    After reading around, one possible reason for that could have been a bad CV joint: I could hear a faint clicking when paying attention at higher speeds at times, and there was a bit of play in the bar segment between the two joints. So I replaced the CV halfaxle. The problem continues. Maybe it wasn’t the CV joints, and I just noticed a pre-existing problem by being much more vigilant...
    I also ended up doing all the same work to the passenger side, and after a day or two I’m hearing the same clunk now happening from that side. As before, a few hundred miles has caused the clunk to happen a bit easier and more reliably.
    My current best theory is the LCA might be shifting between two positions as it encounters force in one direction or another. I’m pretty sure I torqued the two bolts on each LCA correctly (101 ft lb, with the suspension loaded/settled).
    The only thing I can really think of doing is trying to torque the bolts down a bit farther. How far is too far? Is there anything else I should try to diagnose before going down that route?
    It would be pretty easy to change the sway bar links back to see if that was the cause, but it doesn’t feel like that would be the case? Do the sway bar links get much in the way of stress when the car isn’t turning, even with slight applications of gas/brake?
  2. Patrick Wong
    18,200
    6,474
    Maybe an engine mount is failing, which is causing the clonking sound?
  3. Frogblast
    CA
    I inspected as much of the left and right engine mounts as I could see without disassembling anything, no issues. The bottom engine mount looked fine. I don’t feel any unreasonable clunking during ICE start/stop, so I don’t suspect the engine mounts.
    I swapped back to the original sway bar links. No change. I over-tightened 3 of the 4 control arm bolts to 110 ft lb (couldn’t get to the one that interferes with the oil drain pan). No change.
    At this point the only thing I can think of is swapping back to the original control arm, but that’s more invasive than I was hoping to have to do. If that resolves the problem, I have no idea what would be wrong with the new control arm to try and fix it.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Did you use a Toyota oem lca?
    That was a lot of work. Did you have access to a car lift?
  5. Frogblast
    CA
    I used NAPA LCAs w/ ball joint assembly (although I’ve reproduced the problem with the original ball joint).
    I don’t have access to a car lift, I’ve been using a basic trolley jack, a couple jack stands, and some large pieces of lumber to put the wheels on when needing to work under the car with the suspension loaded (I’ll get some ramps someday).
    edthefox5 likes this.
  6. jessiejosco
    jessiejosco Member
    62
    Did you torque the control arm bolts with the suspension loaded? If you don't do this you will likely get a clunk and play in the front control arm bushing even with a toyota control arm. I found this out the hard way. I leave the bushing bolts just lightly tightened and then jack up the suspension to its normal ride height. Then I torque the bolts down.
    Gen2_Accel likes this.
  7. Mendel Leisk
    38,719
    Just reading along I think he did.
  8. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Nice job thats alot of work. Sucks so bad after all that work and still clunking. The bad news is its probably the lca's. They clunk.
  9. Frogblast
    CA
    So I convinced myself that engine mounts were the problem, and finally got all 3 replaced. The start/stop clunk still happens. I guess I should probably take it into a shop at some point, as I'm out of ideas.
  10. Patrick Wong
    18,200
    6,474
    How about the front struts - have they been replaced yet?
  11. Frogblast
    CA
    I actually did those first. They were in for several months before I also changed the control arms, and no problems during that interval.
  12. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Did you lock tight the control arm bolts. I didn't and they came loose creating a clunk also. I took them out and lock tight them and no clunking for 60k miles now
  13. Patrick Wong
    18,200
    6,474
    Sadly, Ed might be right, if the aftermarket lower control arms are of marginal quality.
  14. Frogblast
    CA
    I actually put the original LCA's back in temporarily and the clunk remained, so it's either another part, or Raphael's suggestion about the bolts being insufficiently torqued. I've never used loctite, but I have tried to torque them down somewhat beyond spec. I went 20 ftlb beyond spec, but that wasn't enough to resolve. I wasn't quite brave enough to go further.
  15. Raphael Muscarelle
    661
    222
    I didn't say not torqued enough. Oh I had enough torque. Using a 3ft breaker bar to tighten should have provided excess torque.
    I said they back out even with lots of torque so they need lock tight.
  16. richard203
    richard203 Member
    205
    45
    SF
    im trying to fix the front end clunk or noise when going over bump too. right now i changed the front strut assembly and still have a little bit of front noise. i ordered the front sway bar end link to change them out next i will report back if theres no more front suspenion noise over bump.
  17. richard203
    richard203 Member
    205
    45
    SF
    k so i changed out the front strut fully assembled both side and front sway bar end link. i can still hear clunking nose from my drver side. any idea?
  18. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Please see post #8.
  19. richard203
    richard203 Member
    205
    45
    SF
    i'll into that and post an update if it fix the problem or not.
    Frank1234 and edthefox5 like this.
